Question about Neff Ovens
I have a Neff oven ENR=U1744N0GB/03, FD=8510. After selecting the fan oven mode, the temperature cannot be changed; the temperature adjustment knob rotates but the value in the LED display does not change.
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Posted on Dec 14, 2008
  • 228 Answers
SOURCE: I need to change my neff oven u1744N0GB selector
pull of control knob first, remove oven from housing and remove top panel undo 2 screws holding selector to fascia withdraw it back into top and change wires there will be quite a few dont get them mixed up! reverse to reassemble.
Posted on May 29, 2010
SOURCE: Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Posted on Aug 28, 2010
Cooling fan on my neff oven stays on when I set it in auto is this normal
Are you sure you mean 'C ooling Fan' and not 'Circulating Fan' which should come on if the temperature selection is higher that the current temperature.
Oct 10, 2016 | Neff Ovens
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
USER GUIDES FOR NEFF OVENS
http://customerservice.neff.co.uk/product-advice
Use link, click on product advice, then click download manual, enter Enr (U1422s0GB) to access II (installation) IU (User manual)
Apr 12, 2013 | Neff Ovens
I need to change my neff oven u1744N0GB selector switch. I have a new one, but need to know how to change it out.
May 20, 2010 | Neff Ovens
Tip
Common Heating faults Neff U1721 Electric Oven
on Jan 19, 2010 | Neff U1721 Double circotherm Electric Oven
Oven on fan setting not working ;fan is still working but oven is not getting hot on large oven
The oven element is faulty, and needs replacing.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 12, 2010 | Neff U1452 Double circotherm plus Electric...
How do I find out what model my Neff is please - it is a double stainless steel oven purchased in 2000 ish
open the bottom oven door and you will find a small silver plate on the left side of the oven frame. the model number follows the letters "ENR".
Jun 26, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
How do I switch off child lock from my neff oven 1641
So, you should have a "-s-" being displayed if you have the child lock on.
The switch for selecting the oven mode( oven, fan oven, grill etc)
-from its off position, turn it one click left so the light comes on, and then click it back to off. Do this three times in quick succession. The "-s-" should now have disappeared and you can use your oven again.
Regards,
Steve.
Sep 09, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
62 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
