My twf does not turn on, all that happens is the little red light on the front just flashes, its model twf 4117wd
On the TWF-4117WD when you have just the flashing red light when you press the power button,the fault is a dry joint on an smd link near to the connector at the top left of the mainboard,the first one for the power button etc.
Once re soldered all should be fine,be careful though its only a couple of mm in length.
Posted on Jul 29, 2012
SOURCE: Hi I bought a reconditioned TWF 26
there is a little fuse inside the tv change that but make sure u change it for the right 1 tho or u can blow the main board up
Posted on Jul 18, 2009
  • 117 Answers
SOURCE: tv turned off red light at front flashing nothing
power supply whip it out/send to ohms supplies if in uk
Posted on Nov 17, 2009
SOURCE: Vizio P4 Plasma TV, won't turn on
if your vizo p4 blinks red 10 times its your power supply board ckeck your two fuses on the board,if those are not bad change your power supply board if you can find a board for that model vizio p4 .the phillips tv uses the same board
Posted on Oct 15, 2008
  • 367 Answers
SOURCE: When the tv is plugged
Did you get this fixed?Please let me know.Thank You very much!
Tyler
Posted on Sep 12, 2010
news775
  • 699 Answers
SOURCE: i have a model 42PF9966/79
This is a service code for the engineer.
Please dont forget to vote if you liked my answer
thanks
Posted on Feb 08, 2011
2008 Chevy Silverado Signal lights work in the back but not the front
when last owner put leds in it sounds like they have messed arund with the wiring, i would suggest you check that.
Nov 03, 2016 | 2008 Chevrolet Silverado
Blinking red light
Is the battery door maybe not closing tightly, causing the metal area that touches the tips of the batteries to not be in close enough contact with them? This happened with my camera due to a cracked battery door, and until I can afford to replace it, I've put a rubberband around my camera over the little door to hold the batteries in tightly! Surprisingly, this is working for me! I know it's not an optimal fix, but thought I'd offer the suggestion. (You didn't say what make/model your camera is.)
Nov 20, 2012 | Cameras
Tv doesn't work
If this TV has a lamp it could be it. I need the model number to better figure it out
Mar 08, 2010 | Televison & Video
Wii is comming on but when it says press a button nothing happens new controls aren't working or sensor bar isn't picking it up what to do
You probably need to synchronize your Wii-Motes to your system. When you press buttons on your controllers do the four LED lights flash at the bottom? This is a clear indication. Your Wii needs to be turned on. You need to open the little door on the front of your Wii where the SD card slot is. Under the slot there is a little red SYNC button. Then open the battery compartment on the backs of your remotes. There is another little red SYNC button here. Press the button on the remotes and then while they're flashing on the Wii and it should sync. If it doesn't work the first time try again.
Dec 22, 2009 | Nintendo Wii Console
The television will not turn on. Initially, when the remote (or button on tv) was used you would hear it turn on and hear some volume and then it would turn itself off. A red light would flash, stop...
You did not specify the brand and model of your tv but based on experience the red light indicator flashing means a projection lamp problem. Check the lamp and lamp doors if properly secured. If symptom persist you need to replace the lamp.
Aug 10, 2009 | Televison & Video
Oct 11, 2008 | V, Inc. Vizio P4 Plasma Television
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
