Question about HP DeskJet F380 All-In-One Printer
Won't print i am trying to print a paper out using microsoft word processor and it just keep printing out black paper
    Problem Solver:
  • 9 Answers
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    1. Open the Printer Toolbox .
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    1. Load the input tray with unused plain white paper.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Release both buttons. The self-test page prints.
    This will definitely work for u.
    Thank u.
    Posted on May 28, 2008
    How do I print without a border please 8.3 by 11.7
    Margins are set up in your WORD processor. Presuming you are sung WinWord, you should seelct
    PAGE SETUP
    and succesively adjust Margin, Orientation and Size.
    Be careful that size of paper seelcted be the same size of the paper you are sung.
    Microsoft Word tutorial How to print booklet lynda com
    MS Word Print Preview Tutorial
    Word 2013 Tutorial Previewing and Printing Documents 2013 2010 Microsoft...
    Word 2010 Tutorial Previewing and Printing Documents 2010 Microsoft...
    Sep 24, 2015 | Office Equipment & Supplies
    I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
    Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
    Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
    Black ink won't print and I just changed the ink
    Try using the photo paper option instead of the plain paper option.
    I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
    Hope it helps!
    Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
    The machine won't print. It won't feed paper, The
    Your machine needs to be serviced.
    replace the cartridge with the original one.
    it can not print if one cartridge is missing or not original.
    Jul 12, 2011 | Canon Office Equipment & Supplies
    Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
    If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
    Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
    May 02, 2011 | Brother HL 2140 Laser Printer
    I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
    This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
    May 20, 2010 | HP Photosmart C5280 Printer
    MP 780 DOESN'T PRINT
    Try printing something in a colored font, like red or green and see what happens. This printer uses two black ink cartridges. It uses the larger one for black text printing. If it is dry, blocked, or damaged, your text (usually black) will not print. Changing to a color font will rule that out.
    Good luck.
    Feb 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    IP1000 cannot print black ink
    This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
    It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
    PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
    I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
    Jan 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    HP DeskJet F380 All-In-One Printer Logo
    218 people viewed this question
    Ben Johnson
