Question about Canon PIXMA MP530 All-In-One InkJet Printer
Printing from web
Printer prints same thing over and over till i turn it off
My printer was printing 1 to 4 copies of each job. i phoned the cannon c.o.and they helped me out, i must have been hitting the print button more than once, in my hurry up and get going stance.
Posted on May 29, 2008
How can i print?
Go to the Argox web site does your model printer do labels? check the media spec's. Are using the correct setting in the print driver? Check the printer setting on the machine. web site mite have a work around also might go to web site down load up grade driver to allow ding lables
Oct 16, 2015 | Argox OS-214 Label Printer
How can i get my te m80 till to print it was printing but now nothing on the paper my grandchild was plying with buttons
If it still prints an end of day report, the receipt is probably turned off (press PAPER SAVING button).
If the end of day report comes out blank, make sure you have the shiny side of the paper to the front (only prints on one side). If those things are not the problem, it is probably time for a new printer. The Seiko printers in that model were total rubbish and frequently need replacing if you print a lot.
May 13, 2015 | Retail Supplies
Till roll re-placement not printing
Try turning paper around or make sure you have thermal paper if it is a thermal printer model
Jun 18, 2014 | Casio Parts Cash Register PC Desktop
I have a HP Photosmart C4680 All-in-One Printer. When I connect it to my laptop and turn it on, it starts to do things by itself...like someone is remotely using it to scan, copy or print. I am still...
check for a pending job on your computer, or when it print when you turn on it print a sample page? if so put it face down on the scanner then press the scan button then wait till the power light go on steady,
Aug 09, 2011 | HP Photosmart C4180 All-In-One InkJet...
The printer turn on ok , then whene i print any thing the printer work ok but its not printing on the paper .
It seems like its a jammed print head for this try cleaning your print head using the cleaning utility thats present in your printer software, (NOTE: Head cleaning will consume a lot of ink) Or you can just clean your head with isopropryl alcohol.
Requirements:- 1. Isopropryl alcohol 2. Syringe 10 or 20ml 3. Tube(I used medical tube) that fits in the tip of the syringe and the nozzle
Steps: 1. First remove the needle from the syringe and fit the tube into the tip till its firm. 2. Pull 10 ml of isopropryl alcohol inside the syringe (note: no vacuum or air should remain inside the syringe) 3. Fit the tip of the tube on the nozzle of the print head and slowly squirt about 5ml of isopropryl into the nozzle and pull back till all the isopropryl comes back while pulling back clogged inks will come inside the syringe repeat this till the nozzle is clear. repeat this to all the nozzles. don't forget to throw away all the dirts (clogged inks that will come inside the syringe) and do it slowly, though it will take much time but it will be helpful. I was able to clear my jammed print head with this procedure hope this will help you.
Apr 17, 2011 | Epson STYLUS R230 InkJet Photo Printer
Printer will not print the content from a website. The only thing that prints is the footer. Even when the Print preview shows all of the content on the web page, it will not print on the paper.
Some web pages are made up of two or more frames. If you use the Print button on the toolbar, only the active frame will be printed. To print the web page at it appears on the screen or to print only one frame use the Print dialog window to select what you want to print:
1.To print the web page including all the frames, in your web browser, click the File menu and select Print. In the Print Frames section, select the radio button next to As laid out on screen and click OK.
2. To print one frame, left click once on the frame you wish to print to select it. in the Print Frames section, select Only the selected frame and click OK.
Alternate method: Right click on the frame you want to print, choose Open Frame In New Window, then just print it out from the new window that opens as you would a non-frame web page.
Note: In Windows Internet Explorer version 5 or above, framed Web pages are printed with each frame coming out on a separate page by default.
Jun 22, 2010 | HP Photosmart 2610 All-In-One InkJet...
My printer is not printing with all of the colors and there is banding, brand new ink and printheads changed in the last 6 months.
I'm having a simialr problem, I can get my Kodak EasyShare 5300 printer to print pictures just fine, I can even get it to copy & print from the scanner. In both black and color inks. What I can not get the Kodak EasyShare 5300 Printer to do is to print from Microsoft Office Word, or Works for that matter any text document what so ever. I've never had a problem with the printer ever, not even when I upgraded to Windows 7 it printed just fine up till a few months ago and started acting up. At first I thought it was because I hadn't used it in awhile so I replaced both cartridges so they are brand new. Tried my experiment again and it did the same thing, pictures, and copy and print from the printer works just great...text however from the Word programs....nothing but a blank page.
Running Windows 7 - 64 bit Dell Touchscreen, Dual Core Processor. Before you ask...before this incident the Kodak Printer intergraded just fine and worked without incident. Since it is not the printer portion (unless its the printhead), it has to be a software problem...although, I used the disk that came with the printer to re-install it and not from the web just in case that was the problem. Course would installing the web upgraded software be of any assistance? Anyone have any solutions? Thanks.
Jun 16, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing error log
reset the print jobs then check the printing refeperences.
Feb 08, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Mar 07, 2008 | Office Equipment & Supplies
Says its ready till i try and print
Dell printer drivers try to 'phone home' with Ink usage stats .. even if you select 'no' when asked, they still try to access the Internet ..on install the driver modifies Microsoft Vista Firewall settings to permit this ...
So if you recently installed a non-Microsoft Firewall eg. ZomeAlarm your print driver will be denied access to the web and will refuse to print.
Note that 'deny' is different from 'time-out' ... to test turn off your wireless (or remove the ethernet cable) and ONLY THEN turn off your firewall - if it now starts printing you have your solution (go into Zone Alarm and Enable all Dell & MS print related software access to the Internet).
DO NOT browse the web with your Firewall turned off !!!!
Oct 14, 2007 | Dell Inkjet 720 Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
