SOURCE: phillips external hard drive
If its an usb drive, no driver is required. The drive will show itself in My Computer after it is commected. Uninstall the driver, shut down, connect the device to the computer and start the computer.Tell me if it works. Also, when posting a question, give full details.
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
SOURCE: i have a simpletech pininfarina 500 external
I have found a driver page of simpletech:
http://www.simpletech.com/support/support_downloads.php
I believe that driver for your model is not available in the above link.
The drive would not be recognized when it is not compatible with your notebook hard disk.
I suggest you to contact simpletech for getting the drivers as they will have the hard disk drivers.
SOURCE: Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
