Question about Dell 1815dn All-In-One Laser Printer
Dell 1815dn printer makes a clunking noise when warming up and printing
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
There is a good chance it is the fuser drive assembly. If the sound comes from near the rear of the machine you should try replacing this part (part# D1815-W3). It is not very uncommon for these to go bad causing your printer to be noisy or jam at the fuser. Iteminc.com has these in stock and can ship same day. Here is a video that shows you how to replace this part. Hope this helps. Good luck, and thanks for using FixYa!
Posted on Jul 06, 2011
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Aug 21, 2015 | Dell Office Equipment & Supplies
How do you print an envelope on a Dell Laser MFP 1815dn
when printing enevelopes always ALWAYS THROUGH THE BYPASS open front door and feed thru there. on the bypass is image to let you know fce up or down follow that. also change settings on pc when printing envelopes or cardstock etc.
Jun 09, 2012 | Dell 1815dn All-In-One Laser Printer
How to Determine the Printer Total Page Count on a Dell 1815dn laser printer?
Press the scroll button <--- highlight menu,
select (checkmark)
scroll to Reports, select
scroll to system data, select
Print out will contain the page count
Aug 10, 2011 | Dell 1815dn All-In-One Laser Printer
My Dell 1815dn printer - says the scanner is locked. Makes horrible clicking sound when I try to scan of make a copy. How do I unlock the scanner?
The scanner has a manual lock (a blue sliding switch on the base of the scan bed inside of the printing output slot.)
This prevents the scan head from damage when the printer is moved.
Look and reach inside the paper outlet and pull the latch (located on the left) towards you.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 20, 2010 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn overheats
I'd just call Dell tech support. If you complain about a heat problem, it's part of their policies to simply replace the unit for safety reasons. :)
Dec 31, 2009 | Dell 1815dn All-In-One Laser Printer
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner locked printer dell laser mfp 1815dn
The lock for the scanner is on the roof of the cavity where the printed paper comes out. Simply flip it to the other position and restart the printer.
Jun 03, 2009 | Dell 1815dn All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
166 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
