Question about Intel Motherboard
"no signal" on monitor, my cpu fan is working fine but beep sound is not coming
    Sergeant:
  • 180 Answers
Hi
Try this steps:-
1.Please check your power cables properly.
2.Remove the monitor cable from CPU and turn on the monitor and see are you getting the dispaly or not.
Posted on Oct 04, 2010
I have an hp pavillion a6500f that soon as it is turned on has a constant alarm and is not sending a signal to the monitor. Screen says no signal and then remains black.
If you mean a constant beeping, open the case and see if the CPU fan is running, check also that the heatsink is firmly attached to the board, this noise usually points to a n overheating CPU, if you get no activity on screen,it is because there is no signal being sent to the monitor. Do not operate the computer until you have checked the fan is working, you need to establish if there is power getting to the fan by testing with a multimeter on the motherboard cpu fan pins. If you are getting power, replace the fan, worthwhile removing and regreasing the CPU and making sure it is firmly in place.
If there still is no signal, replace CPU, but also try a different graphics card (faulty video will give 9 beeps).
After that, check the ram is firmly in place.
Jul 28, 2011 | HP Computers & Internet
My display unit of my ACER PC show no signal,but it is on. what can be the problem?
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Jun 02, 2011 | Acer AL1716 17" LCD Monitor
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
Worked fine last night, discovered it this morning still turned on but no signal to monitor. Rebooted and it began a consistent beeping with no signal to monitor. Unplugged several times to no avail....
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Dec 13, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
No display no beep sound
you need to check your memory RAM of your PC. if it is ok or not. try to swap to another pc or tighten it.. cheer ^^
Jul 20, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
L7VMM2 wont boot (no post) plz help
Sounds like the CMOS battery on the motherboard needs replacing...i would try clearing CMOS first, replace battery and test voltage at the CPU (through the BIOS) If that dosen't help you likely have faulty capacitors.
If you get it to boot, im sure drivers and BIOS will need updates if it's been stored 2 yrs.
Jun 01, 2009 | EliteGroup L7VMM2 Motherboard
When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Dec 12, 2008 | Computers & Internet
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
New Acer Aspire E700 does not load-up
Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
Jan 01, 2008 | Computers & Internet
Intel Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
