Question about Kitchen Ranges
Error Message on GE Profile JBP48B0H1BB Electric Range
A couple years ago, I was boiling a pan of water (on an eye closest to the control panel) and forgot about it (the pan boiled dry). I then received an error message on the display, which read "F7 57". Now, anytime the oven is in operation for too long, the same error message will display and it will shut off. It's kind of like the oven has overheated or something. The stovetop will still function, but the oven will not work again until it has cooled down. I can blow a small, desktop fan on the control panel and it seems to prolong the use of the oven somewhat, which is weird.
Do I need to replace the control panel? GE/GE repairman WILL NOT HELP AT ALL!!
KOakaKO
  • 135 Answers
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Posted on Aug 09, 2007
SOURCE: cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Posted on Apr 03, 2008
fridgetech
  • 473 Answers
SOURCE: panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Posted on Dec 02, 2008
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
  • 1214 Answers
SOURCE: older ge spacemaker range, temps wont boil water
Check your breakers to the oven. It sounds like one of the two of them have tripped and you are only getting 120 VAC.
Do you have a volt-ohm meter, and know how to use it?
Posted on Dec 18, 2009
Testimonial: "good thinking! now where are breakers? need to pull out stove?"
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Tip
GE Range flashing locked after boil over
GE Electric range with front controls. I had a pot boil over and spill over the front of the range, some water got on the membrane key panel. But I’m assuming some went behind the panel on to the control board. The LOCKED button started to flash randomly and the electric door latch was engaging and disengaging also randomly. Unplugging the unit and looking for any type of reset button did not help. The control board which is mounted behind the membrane panel got wet and was causing a short. Luckily it survived. I fixed it by removing the four stove knobs, four retaining plastic nuts that are mounted behind the knobs, and then the four (2 and 2 outer most) 1/4” bolts that hold the main panel on. I dried out the electric front door switch and the electric panel with hairdryer for 10 minutes. Plugged it back in and its all fixed. . No so good design to allow this to happen so easily so as I assembled it back together I put silicone around the membrane panel in hopes of preventing this from reoccurring.
on Apr 26, 2010 | Kitchen Ranges
Ge profile electric range f0
You need to replace the control panel.
Jul 09, 2017 | GE Profile JS968 Electric Kitchen Range
Ge profile dbl oven keeps reading error message F7. Put cardboard card around ribbon cable on back of controller as advised a year ago on this site. We have moved it & changed it and now it works...
The F7 error code means that a button on the touchpad is stuck. What the proper repair procedure is,is to first replace the touch pad and if F7 returns replace clock (also known as eoc or control board) Do not take this wrong but a no point in my 30 years appliance repair career exchanging info with my coworkers or even factory trainers at training sessions have i ever heard anything about putting cardboard around the touchpad ribbon cable.
Gene
Aug 11, 2011 | GE Profile JKP56 Electric Double Oven
I have a ge profile spectra electric range not sure of model when i use oven tocook when i shut off oven a error F1 and continue with a beeping noise until oven cools down
Hi
Thanks for using FixYa. F1 error means that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | GE Profile Spectra JBP95 Electric Kitchen...
Ge range js968 f0 error code
F0 error code is a failed thermistor control. The suggested fix is to replace the ERC(electric range control). You will need to inspect the ERC, touch panel, ect for any loose connections that could be causing a short. You can also try unplugging the range for 15 minutes or so and see if the error code clears. If not the ERC may need replacement.
Jan 15, 2010 | GE Profile JS968 Electric Kitchen Range
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
F7 error
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
