Question about Pool & Spa
I purchased a new heater for my AMPAC Pulsar series micro spa controller model no. 2083 15 amp and now need assistance in rewiring the heater into the contol box. Could you please send details of what colour wires go where. Thanking You, Kind Regards, Sally Pickess.
1234s282
  • 144 Answers
SOURCE: Mainboard Data Needed
All Your Motherboard Specifications Are Here
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=674&CategoryID=1&DetailName=Manual&MenuID=44&LanID=9
All Downloads/Drivers Here
http://welcome.hp.com/country/us/en/support.html
Click "Start Detection" and the tool detects your model number and displays all the drivers
Please Rate My Solution
Posted on Jan 07, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
zayn22
  • 10 Answers
SOURCE: wiring diagram for bajaj pulsar 180
see your owner manual.....
Posted on Aug 14, 2009
protek480
  • 1714 Answers
SOURCE: camper place says my converter is dead / need to replace
This is not an easy project for most. I have 30 years in the electrical control business and it would be a pretty good job for me too. I would want to know a bit more to make a recommendation. Here's a photo of a 'one line diagram' of what you want (in a nut shell).
Posted on Sep 17, 2009
How do you set up the timer for heating a ampac pulsar series spa?
http://waterheatertimer.org/How-to-set-timers.html
Link above has instruction resources for analog and digital timer modules.
Repost question and describe timer in detail
Gene
Water Heater Timers Save Money
Jan 04, 2015 | Hardware & Accessories
Unlock hot tub control panel
Panel needs to be in the display of "Time" 1st. If not, push the "Prog" button to get there. Once the Time is displayed, push & "Hold" the "UP" button for at least 5 seconds. The Lock icon/symbol will be displayed - panel is locked. Release and hold the UP button again for at least 5 seconds, the panel will then be unlocked.
Nov 29, 2013 | Pool & Spa
Rp2100 main board has a piggyback circuit board attached to it with 2 relays controlling or wired to 2 jandy actuator valves. I upgraded heater to a new raypak heater & have no clue how to rewire with...
The new board may have the actuator relays and connectors on the main board. If so plug the wires in. If that is not the solution then you can call the Raypak technical support line and they may be able to direct you. Good luck.
Aug 11, 2011 | Raypak RP2100 Heater PC Board Control IID...
How to set timer on my hottub
Hi, we have an ampac pulsar series timer on our spa. We are not sure how to set it, as we bought it second hand and have no booklets. Can you help?
Mar 21, 2010 | Hayward H Series Pool & Spa Heater 400k...
Layz spa keeps going off says on readout 6cf.heater is fine pump everything else is ok cheers kevin
You have a problem with the RCD (residual-current device). This is the part of the plug that you have to push reset on before a current will flow. You can repair this by buying a new RCD plug and rewiring it or if you already have an RCD socket adaptor for another appliance, you can just cut of the plug on the pod/ pump and rewire it into a rubber plug and then plug this into the RCD adaptor and the lay z spa should no longer cut out. The RCD is important because you do not want to blow the unit inside.
I hope this helps, If you need more assistance, please ask.
Sep 30, 2009 | Pool & Spa
Where can I get a new control panel for my Hayward H Series above ground pool heater? What information do I need to obtain the correct part? Thanks
They are available all over; Try local pool stores or online. You would want the model and serial number off the heater frame to be sure you are getting the correct part.
Jul 29, 2009 | Hayward H Series
Pool & Spa Logo
183 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
