How to Replace New Hose at Auto-Reel 2490. Please let us know, we have 5 sets to be replace. Thank You and Best Regards, Neo Aik Kheng Novomatrix Pte. Ltd. Singapore Mobile 65 - 9641 5921
  • 67 Answers
The auto reel is guaranteed for 2 yrs against faults arising from defective manufacture or materials. the hose is guaranteed for 15 yearsaginst defective manufacture or materials. all that is needed is the purchase reciept. if this is available with you you can contact hoselock cunsumer care.
as an added advantage here is the download link with instructions for assembly,installation, use and maintenance with diagrams in pdf format hope this helps http://www.hozelock.com/uploads/pdf/instructions/watering%20instructions/2490%20Auto%20Reel%20instructions.pdf
Thanks for using fixya
Posted on Oct 04, 2010
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How can I fix a hozelock hose reel that has been pulled out too much and jammed?
you have to take the cover off and redo the hose you can re reel back in
Jul 19, 2014 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How can i fix a leak inside my hozelock auto reel
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
Jun 01, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Lost return tension when replacing hose
Where can I get a replacement tension spring for my auto reel hoselock 2490 ? I have tried everywhere but without success. Any help is much appreciated
Mar 19, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Craftsman 3/8 in. x 50 ft. Air Hose Reel, Retractable how to replace hose
Unreel the hose all the way out. Unscrew brass fitting at reel. Screw on new hose with fitting tape. reel up new hose. You're done. Good luck.
Jan 07, 2011 | Suncast Air Hose Reel GCWAR50R
Coolant leak on a HOnda Accord LXI. I think the leak is from a hose running from the throttle body, to the block itself. Whats the name of that hose as I cuold buy a new one and replace it? Thank you
There are LOTS of these little 5/16 size hoses on these cars . None of them have a real name . The best way to fix it is to find the one thats leaking and take it off and take it into the auto parts store with you . I had to put new ones on mine and I just got 6 feet of hose and a box of clamps and cut the hose to fit and it worked great !!
Mar 05, 2009 | 1989 Honda Accord 4 Door
Teac A2020 reel to reel 60,s
Hi ferris,
Are you talking about a wheel or a belt? If it is a belt you can go to a vacuum cleaner shop and match one up( make it just a little small) and it will work just fine. I have done this with perfect results.
Best regards, Mike cannon6111@bellsouth.net
Jan 10, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Computers & Internet Logo
259 people viewed this question
David Payne
David Payne
