Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
I dont know how to program
I have all the gear but i dont really understand the rss, i want to put conventional bands in groups, ten channels to each bank
1. Program the ABC switch as zone select.
2. Program each 'personality' into the proper zone (eg A1, A2..., B1, B2..., C1, C2..., etc)
3. Load the codeplug into the radio.
Posted on Jun 03, 2008
What does it mean when it says 'OUT OF BAND'when I try to put in the code?
It means the frequency you are trying to put in, is not within the band you are connected to.
Wiki describes it thus
37px-wiktionary-logo-en.svg.png Look up out-of-band in Wiktionary, the free dictionary. Out-of-band is activity outside a defined telecommunications frequency band, or, metaphorically, outside some other kind of activity
Feb 01, 2016 | Uniden BC 125AT
Tip
Twitter How to Create Custom Groups
Copy the RSS link at the bottom of your Twitter page.
Go to Yahoo Pipes.
Create a new pipe.
Set the URL of the RSS as the "Fetch Pipe".
Add a filter.
In the title put the real names of people you wish to follow, in case you don’t know there names, but know there Twitter nicknames use these in the "Guid field".
Connect all the pipes.
Publish it, Visit public URL of the pipe output, here's your Twitter custom group.
Found this great tip at - http://www.christopherspenn.com/2007/03/05/how-to-make-custom-twitter-groups/
Enjoy
on Sep 24, 2008 | Twitter Tweets
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
Manual Programming of the Uniden BC95XLTB
1. The scanner automatically selects the band, you just program the frequency.
2. Your scanner does not have the traditional channel/frequency layout that you may be used to. Rather, it uses a system called DYNAMICALLY ALLOCATED CHANNEL MEMORY, which organizes frequencies into groups and systems, and enables the scanner to cover a wide variety of conventional and trunked radio systems.
The manual for the scanner goes into detail on the various systems and programming methods, and you can download/print the full manual here:
http://www.uniden.com/pdf/BC246Tom.pdf
If it seems a bit overwhelming you might want to join a scanner group on line or in your area and draw on their experiences with the 246. You can also pick up a lot of useful information on the scanner, and access a comprehensive database of active frequencies/systems in your area by joining
www.RadioReference.com
To simplify the programming process, you can join the Radio Referenc group and purchase programming software from BuTel (http://www.butel.nl/) Their program for the BC246T will allow you to access the RadioReference database, select what you want to monitor, and import/program the information to your scanner.
Sorry, but the days of the Bearcat III with it's manually selectable bands and 8 "rocks" are gone, and today's complex radio systems require complicated scanners to keep up with them. As more and more areas upgrade to trunking systems, machines like the 246 will become the norm.
Dec 21, 2009 | Uniden BC246T Handheld Scanner
Have uniden 396T. Control channel now on one system does not work
Have you put in more than one control channel for your area.
I always put as many of the red or blue Control channels in my area. I counted 23 Control Channels for the whole system. I would put everyone in if it were me.
I set the system up as "Control Channel Only".
In a metroploitan area you should be able to pick up another control channel on the system.
I use the Arc396Pro Software ato program my scanner. (available at ScannerMaster) I know in the Pro version you can download the information directly into your scanner. You can try this to be sure your settings are going in correctly.
J
Nov 16, 2009 | Uniden BCD396T Handheld Scanner
Kenwood tk-840 programing software , where to get it and alittle info on the uhf
The only legal way you can get the software is to buy the software from Kenwood or one of its dealers. Since the radio is old and not longer supported Kenwood no longer sells the software and no agent is going to have legal copies of software to sell. So from a legal standpoint you can not program the radio. If however your willing to be a software pirate and ignore a corporate copyrighted piece of software, you can find software on the net and sometimes on ebay. nuff said on that.
Forth: the tk-840 is a nice radio, can be found pretty cheap, will do trunks or conventional groups. The only big problem with the 840 is scanning. It scans "ODD" instead of scanning a range of channels, it scans a single channel in a group. You can have only 1 channel is a group scanned. Kind of like scanning columns instead of rows. If you only need 32 channels you put 1 channel per group and you will not get confused.
Nov 09, 2009 | Kenwood TK-3102 4 Watt UHF Professional...
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
For a comprehensive database of active frequencies in your area, visit
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Trouble adding frequencies
first press man, then the channel number you want to fill, then man again, then pgm or program, type in the frequency, and hit enter ( could E or ent). next repeat this process for the next channel you want to program.
Nov 15, 2008 | Radio Shack Radio Communications
How to prograqm a motorola mts 2000 flashport?
May 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Unintelliginle
Radio reference guide on the internet will be your path. You will choose your state, county, city, PD or Fire and there you will find The talkgroup ID's.
Mar 12, 2008 | Uniden TRUNKTRACKER III
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
90 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
