Question about Refrigerators
Water is leaking from the ends of my 230L godrej frost-free refrigerator. Plz help me with regards to solving it myself or estimating the cost
huuum
  • 750 Answers
SOURCE: whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Posted on Oct 05, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
woodchuck789
  • 4059 Answers
SOURCE: Zanussi frost free fridge freezer leaking
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: Water leak from Refrigerator
Posted on Jul 02, 2009
  • 21 Answers
SOURCE: My Kenmore refrigerator is leaking water from
This sounds like that you might have a defrost drain pluged up. Depending on the model #, You might try this. Unplug the refrigerator. Take the cover located in the back of the freezer. (from the inside) Four or six screws (Depending on model #) and it will come off. If you have an ice maker, you need to take that off first. You will now see the condensor coils (CAUTION fins are VERY sharp). Located in the middle of the bottom under the coils is a hole. This hole is the condensate drain hole. You might try pour hot water down this hole or you can get a steamer and blow steam down said hole. Rember if you pour water down this hole you will have to drain the defrost pan under the refrigerator. To do so gentely grab the side of the kick plate and pull (depending on model # you might have two screws located on each side) On the left side bottom is where the condensate pan is located. Gently pull and dump out the watter and reinstall. Then pour more water down the hole on top and watch the water flow down into the defrost pan. Dump the pan when needed. When the water flows freely, put it all back together and plug it back in and wait 24 hours and see if that fixed it. If not repeat the steps again. Hope this solved your problem.
Posted on Aug 17, 2009
Maytag top freezer refrigerator leaking water
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Heavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Hope this may help you;
Regards,
VOTIT
Sep 07, 2008 | Refrigerators
My roper refrigerator has a freon leak can i repair it myself?
I would say You need new fridge. Roper fridge will cost less then repair, because You will have to call refrigeration company. Job is costly, would estimate at 500$-1200$. Hope that helps!
Aug 19, 2015 | Roper Refrigerators
Water leaking in at the bottom of the freezer and the draw jamming with ice. This is a frost free refrigerator and freezer.
Sometimes a solid ground wire
wrap around the defrost heater and the other end stuck in drain hole has helped for me. Avoid letting the wire or whatever to touch the plastic side of the hole.
Aug 01, 2011 | LG LRBN22514ST Bottom Freezer Refrigerator
Jul 01, 2009 | Refrigerators
Freezer is not freezing its cold like the fridge but thats it. tha fridge is running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator trips the aerth leakage in house every 45 min - 1 ho
Problem solved. The drain pipe from the frost free elements were blocked and caused a short to earth when defrosting cycle started and that caused the problem. when I opened the pipe the water drained and end of problem.
Regards
Koen Malan
Mar 27, 2009 | Daewoo Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
