VENKI.ESHWAR71 want 6RA70AND 6RA20 DC DRIVE OPERATING AND COMMISSIONING MANUAL
The rollover of my 401k. Who should i file a complaint against ICMA-rc with?
https://www.sec.gov/answers/401(k).htm
U.S.Security and Exchange commission refers complaints to
U.S. Department of Labor
Employee Benefits Security Administration
200 Constitution Avenue, NW, Room N5623
Washington, D.C. 20210
Toll-Free: 1-866-444-EBSA (3272)
Phone: (202) 693-8664
Nov 07, 2017 | Cars & Trucks
I don't know which power adapter to use and I can't locate my user manual. What is the DC input? My problkem is I need to make sure I provide the right DC input - I have several adapters - what is the...
Most externals are 12v input voltage so as long as you have a adapter with this input voltage your be fine, and the hard drive should operate.
Let me know if you need more information.
Thanks
Jason
Oct 15, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I need the operating manual for british gas wireless central heating thermostat control RC2, WR1, UP2.
These are Drayton Digistat controls re-badged. RC2 = Digistat2
WR1 = Digistat SCR
Cannot now find manual for Digistat2, but updated Digistat2+ can be found at http://www.draytoncontrols.co.uk/Digistat2RFProgrammableRoomThermostatWireless.aspx
The Commissioning Guide will show the SCR and now to reset it.
Sep 11, 2010 | Heating & Cooling
395 Service Engine Error
Hello kieran,
This might help you. I found this on one printer forum.
From the manual:
Fuser Drive and Contact Cam System Service Check
Error Code 993: Indicates the cam sensor has not been activated.
The sensor activates when the fuser drive motor turns the cam disk.
If the fuser drive motor does not turn on, or the drive parts are not
operating, go to A.
If the fuser drive motor turns and appears to be operating properly,
and the cam is turning, go to B.
and the cam is not turning, go to C.
A The fuser drive system is not operating properly.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
Check the fuser assembly internal drive gears
for binding, or broken or worn teeth. If a
problem exists, repair or replace the fuser
assembly.
Remove the fuser drive motor from the stay
assembly, leaving the motor cable connected
to the motor. Turn the printer on, but do not
allow the motor to touch other areas of the
printer. Verify the motor turns during POR. If it
does, the problem is most likely in the motor
mounting stay assembly. Go to step 2.
Check the motor for shorts between the case
and each motor winding. If a short is found,
replace the motor.
Note: Damage to the engine board may result
from a shorted motor.
Check the motor for open windings. If found,
replace the motor.
Check continuity of the fuser motor/paper feed
motor/carriage unit motor cable.
• If incorrect, replace the cable.
• If correct, replace the engine board.
2 Motor Mounting Stay
Assembly
(Fuser Drive Parts)
Check the fuser drive gears, gears C3-1, C3-
2, the clutch spring, motor drive gear, gear C2
and C4 for signs of chipped gear teeth, worn
parts, or improper operation. If problems are
found, repair as necessary.
Check the cam gears and solenoid for proper
operation and signs of broken or worn gear
teeth or damaged parts. If found, repair or
replace the motor mounting stay assembly.
B The fuser drive system is operating properly and the cam disk is
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
Be sure the cam sensor is mounted correctly
and locked into place.
Check the following voltages on the cam
sensor:
Pin # Signal Voltage Voltage
Voltage Disc in Disc Out
1 (Orange) +5 V dc +5 V dc +5 V dc
2 (Brown) -CCSENS +5 V dc 0 V dc
3 (Green) GND 0 V dc 0 V dc
Note: The voltage on pin 2 should vary, as the
cam turns from approximately 0 V to +5 V dc.
• If the voltage on Pin 1 is incorrect, check
the cable. If incorrect, replace the cable.
• If the cable is good, replace the following
FRU's in the order shown:
1.Cam sensor
2.Engine board
3.SN cable
C The fuser drive system is operating properly and the cam disk is
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
Check the solenoid for proper operation,
making sure it picks during POR cycle.
Disconnect the solenoid and check the
resistance on the solenoid cable. It should
measure approximately 65 ohms. If incorrect,
replace the solenoid.
Check the voltages on the solenoid cable
connector.
Check the following voltages on the contact
cam solenoid cable connector:
Voltage Static Picked
1 (Red) +24 V dc +24 V dc +24 V dc
2 (Black) -SL2ON +24 V dc 0 V - +24 V dc
Note: All voltages are approximate.
continuity of the CRF cable to the cam
solenoid.
Assembly
Check the clutch spring, clutch boss, clutch
disk and gear C4 for signs of wear, broken
teeth or binds. Repair or replace the motor
mounting stay assembly if a problem is found.
Normaly the fuser is not turning - check the cleaner pad is not jammed in too tight. Then replace the fuser drive block 12G1348.
Jul 29, 2009 | Lexmark C510 Laser Printer
Error message 993, what is this?
that is a fuser drive error on printers. it is the part that fixes the ink to the paper.
i have a check for you but is not an easy fix.
if fuser drive is gone will cost approx £12 to replace.
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio GX3050N Printer
Gx3050n error code 993 what is this?
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio CL1000N Printer
Hard drive not recognized
hi I am using Hitachi external hard disk with aluminum case. When I connect my hard disk with my PC it is not recognizing my hard disk. I want retrive my data from the hard disk please let me know the solutions.
Thanks,
K.Venki
Jan 07, 2009 | Computers & Internet
Digital signal
No read this. you may have a lawsuit. February 7, 2008
VIA CERTIFIED MAIL
RETURN RECEIPT REQUESTED
Job Lot Wholesale & Retail Stores #2
86-01 Rockaway Beach Blvd
Far Rockaway, NY 11693
Job Lot Wholesale & Retail Inc.
87-85 Parsons Blvd
Jamaica, NY 11432
Attn.: Yosef Ben-Aderet, Chairman or Chief Executive Officer
Re: File No. EB-08-NY-029
Citation No.: C20083238025
Dear Retailer:
This is an official CITATION, issued pursuant to Section 503(b)(5) of the
Communications Act of 1934, as amended ("Act"), 47 U.S.C. S: 503(b)(5), to
Job Lot Wholesale & Retail Stores #2 and Job Lot Wholesale & Retail Inc.
(collectively "Job Lot") for failure to provide appropriate Consumer Alert
disclosures on analog tuner only television receiving equipment in
violation of Section 15.117(k) of the Commission's Rules ("Rules"), 47
C.F.R. S: 15.117(k). As explained below, future violations of the
Commission's rules in this regard may subject your company to monetary
forfeitures.
On January 30, 2008, agents from the Enforcement Bureau's New York Field
Office visited Job Lot at 86-01 Rockaway Beach Blvd, Far Rockaway, NY
11693, and observed that Job Lot did not have the proper Consumer Alert
VCRs, DVD players, and similar products. For more information, call
the Federal Communications Commission at 1-888-225-5322 (TTY:
1-888-835-5322) or visit the Commission's digital television website
at: www.dtv.gov."
Accordingly, it appears that Job Lot has violated Section 15.117(k) of the
Rules by failing to place conspicuously and in close proximity to the
following equipment, in clear and conspicuous print, the required Consumer
Alert label:
Manufacturer Device Model # Number of Units
Symphonic TV WF24T5 1
Magnavox DVD/VCR MDV530VR 2
Magnavox DVD/VCR MWD2205 2
Magnavox VCR MVR450MG 1
Emerson VCR EWV404 3
FEDERAL COMMUNICATIONS COMMISSION
WASHINGTON, D.C. 20554
Nov 18, 2008 | Symphonic ST413C 13" TV
Request for Base Transceiver Station (BTS) Installation, Commissioning, Integration, Reengineering, Rdio add introductary data
It differs from product to product
I would sujjest first  you choose a product for a base station installation and commisioning and then read their manual
This way you can learn
Feb 23, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
