Question about GE Washing Machines
I own a GE front load washer (Model # WBVH5300KWW) for about a year. On a color cycle, water (cold) does not run and the wash never starts. On a white cycle, water (hot) runs and cycles up to the rinse and then stops. I use the rinse and spin cycle to complete the rinse cycle and then have to switch to the drain and spin to complete the wash. I've checked the drain and there is nothing preventing the drain. Research says it's the control board but I'm not sure. I need some expert advice from someone that has been thru this problem. Thank you
5 Suggested Answers
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
HIRAM517
  • 59 Answers
SOURCE: Ge PRofile Mod # wpsr31001ww
CHECK THAT DRAIN PUMP IS NOT CLOGGED, THEN CHECK DRAIN HOSES, . IF NOT CLOGGED, IF GOOD THEN CHECK PWR TO DRAIN PUMP. IF U GETTING PWR TO PUMP,AN NOT SPINING OR HUMMING REPALCE PUMP
Posted on Aug 19, 2009
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Not geting the cold water. Only once and a while even though set on Bright colors
Fixing a Washing Machine with Slow or No Cold Water Fill ...
? 7:40
www.youtube.com/watch?v=c5r49nuMjao
Feb 10, 2014 - Uploaded by SamuraiRepairman On washers with this problem that do the rinse cycle with coldwater only, the ... Top comments .... It's a front loading machine so I can't open it when it's on. .... GE Washing Machine Repair - Water Overfills, Overflows Washer ...
Aug 09, 2015 | GE WHSE5240D Top Load Washer
We have a ge front load washer model # wm2487hrm . for about a week now after we run a wash cycle the main soap dish is completely full of clean water what could cause this thanks for any help Brady
That model is not a GE, it is an LG. 1. Dissassemble and clean out parts of the dispenser. Re-assemble. (could be not syphoning out the dispenser completely) 2. Check the screens inside the washer (esp. the cold) to see if it is plugged / restricted 3. water valve could be seeping water by.
Jan 26, 2011 | GE Washing Machines
Grease looking stains on clothing after washing in front load washer. Not on all clothing just certain items. Normally notice it on darker colored clothing.
that is leftover soad and down that is building up inbetween the inner and outer tub .....
frontload washer tend to wash in cold an d luke warm water down and most softner detergents are mader from animal fat means it not getting washed away so it cakes up and eventualy this cake deosit get heavy enouhk and fall and fet redeposited on yoour clothes ..... make sure you are using high efficiency soap and run a clean cycle every month with the hotest water cycle with a afrresh tablet for front load washers
Jan 24, 2011 | GE WSXH208A Front Load Washer
My GE washer wbvh5300kww beeps at me when I hit start
I am also having this problem as well. Trying to seek (once again) a solution as having to plug/unplug the washer before each use is really annoying.
Can anyone tell me how to run the test mode for this washer? I don't see that detail anywhere in my manual. Thanks.
Oct 27, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
128 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
