Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
Hi, When I switch the camera on the lens pops out and it makes some noises, then the lens goes back in and the camera switches off. It works ok. if you just want to look at images by pressing the green arrow button, please help
    Brigadier General:
  • 3,006 Answers
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Casio service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
My Lumix DMC FS5 is not working
My Lumix does that when the battery is too low.
Jul 31, 2014 | Panasonic Lumix DMC-FS5 Digital Camera
Dropped my camera and now lens stuck out and beeps and switches off
Hi
Do you get a E18 in the bottom left on the camera screen before the Canon PowerShot A95 switches off?
If you do see this error code then t
he problem could be because dirt or sand has got into the lens mechanism.
Firstly you should contact your local Canon repair centre and Canon may fix it for free. If this fails you can try the suggestions below, but you do so AT YOUR OWN RISK as this could make the problem worse.
Make sure the batteries are new or if you are using rechargeable batteries they are fully charged.
a) Remove the batteries from the camera, and unplug any USB cable. Wait for 5 minutes, then put them back in and switch the camera on.
b) Try using compressed air with a fine tip. Use between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove any dust or sand. Turn the camera on and see if operates correctly.
c) Another, slightly unusual method is to gently tap the padded USB cover part on a hard surface. Amazingly this does sometimes work.
d) Lastly, you can try and force the lens back into the camera. With the camera switched off place the camera on a surface with the lens facing up - look at the spacing between the lens and the lens housing. If it is not even all the way around the lens VERY VERY GENTLY press down the lens on the side where the gap is the biggest. Hopefully you should hear a reassuring "click" as it pops back into place. Try powering the camera back on.
If these suggestions do not work then you are looking at a professional repair.
David
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
Hi when i switch the camera on the shutter comes out ,a strange clicking noise and the shutter goes back in ,it is only 4mths old .
Hi there its a problem of your camera lens guide pin. Which is operate your lens for focusing. Thats pin is damaged & thats why shutter comes out ,a strange clicking noise and the shutter goes back in . Thanks.
Mar 25, 2010 | Kodak EasyShare M420 Digital Camera
My camera makes a clicking noise when i record video. why?
This camera has an auto lens. Which means it will focus automatically every second you can turn this option off:
1: Go into the menu
2: Chose option Cam Settings
3: Switch AUTO focus to single lens and click OK.
Jan 03, 2010 | Kodak EASYSHARE M340 Digital Camera
V570 Dual Lens, will not switch to ordinary lens.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
Jun 10, 2008 | Kodak EasyShare V570 Digital Camera
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Fuji FinePix F470 Digital
Try another battery, it's possible current battery no longer viable or needs a deep discharge recharging.
Dec 27, 2007 | Fuji FinePix F470 Digital Camera
Fuji Fine pix F470 digital
Shoot, I have the same problem and posted the identical question along with this one. I'll respond her if I hear anything.
Nov 24, 2007 | Fuji FinePix F470 Digital Camera
Camera switches itself off seconds after turning it on
This is a service center job and I think the lens assy motor is jammed. Take to a near by camera repair center
Feb 04, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
150 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
