Question about Raymarine C70 GPS Receiver
Good morning When I switch on my C70 i have not the normal screen, only vertical lines. Sometimes the screen works, but next time the same problem appers...vertical lines e can't use it. Can you help me? Best regards, Antonio
  • Gimpy-Binky Warburton
    Gimpy-Binky Warburton May 18, 2014
    This happened to ours multiple times. Raymarine was useless. I found on a forum a solution that worked for us. It does require opening the chart plotter and accessing the terminal strip that connects the screen to the boards. It took me about an hour from remove and reinstall. Separate the internal boards to access the terminal strip, apply pressure and you will likely feel it engage further. Reverse the dismantle process and it should work.
    Problem Solver:
  • 6 Answers
I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes
The solution is simple: press on the edges of the screen and the contact is re-established.
Posted on Dec 05, 2010
Sony KDL43W800C 3D LED TV coloured vertical lines on the screen.
The panel is Faulty
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 24, 2016 | Sony Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My c70 today, went from normal operation to a screen full of flickering vertical lines. Any clues as to what is wrong??? Cheers Peter
The cause: damp.
Easy solution: press on left side of screen. Voila!
Longer answer:
The connection between screen and computer is made bij means of a long, small horizontal strip with multiple connections in the vertical plane.
The strip sits loosely between the left side of the screen and the print.
When damp occurs the connections between the screen and the computer can be lost.
Helping to re-establish the connection by means of light pressure on the left side of the screen solves the problem.
Mar 20, 2011 | Raymarine C70 GPS Receiver
The display on my C70 will suddenly go to a series of vertical lines. Sometimes light finger pressure on the display will cure it. What is the permamant solution
Nov 19, 2009 | Raymarine C70 GPS Receiver
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
The display of the C70 has stopped working. Instead of a picture it only shows either vertical bands of color or just black/white vertical/horizontal lines. Occasionally the display comes back but only for...
Jul 18, 2009 | Raymarine C70 GPS Receiver
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Raymarine C70 GPS Receiver Logo
740 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
