Question about Samsung Cell Phones
Spilled pop on it----need to open and clean - Samsung Cell Phones
  • CommCentral
    CommCentral Oct 04, 2010
    what model do you have ?
  • jhgh Oct 04, 2010
    sch-u490
    Sergeant:
  • 237 Answers
We don't have instructions for that model but you might search google for 'u490 samsung disassembly guide'
CommCentral
Posted on Oct 04, 2010
How to fix a hp dvd740 that sat for awhile after a pop was spilled on it. I need to know how to set the internal adjustments
You need to stay away from adjustments as that will render it completely useless. Concentrate on cleaning the goo out of the drive (especially from around the drive motor and lense) and retest.
Apr 01, 2014 | HP dvd740i DVD±RW Dual Layer Burner
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
Batteries were wrongly inserted.now corrected but all buttons nowproduce a 7
Either something was spilled onto the remote, or the remote itself is malfunctioning. You can try to remove the batteries, pop open the case with a flat head screw driver, clean the rubber buttons/electrical board with q-tips dipped in rubbing alcohol; or buy a new remote for under $20.
Aug 25, 2013 | Televison & Video
Compaq presario cq57 keyboard wont work
Hi ,
Yes it can , If you know what your doing , open the laptop up to expose the keyboard , then clean and dry the keys very well and put it back together , let me know what happens ,,,,,,Goodluck Roy
Oct 30, 2012 | HP Compaq Presario CQ57 Laptop AMD DC...
Delonghi Magnifica door comes open after grind and just before brew?
try changing the defusser..... bsc appliances 07779933829 postal service too.
Feb 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Put new batteries in and no matter what button i push channel 44 comes up on tv.
This is usually caused by liquid being spilled on the remote. This gets under the rubber membrane as the membrane has to have holes in to allow the air to be pushed out and pulled back in when you press the buttons.
Fixing is a nightmare as it involves opening the remote. Most nowadays are very well clipped together and you often break them when opening.
Most cleaning products corrode the carbon contacts inside the remote and so do most commonly spilled liquids like pop.
If you can prise the remote open easily, clean with very slightly soapy water and leave to air dry before re-assembly.
Otherwise, spend a few quid on an universal remote or buy a replica remote from somewhere like CPC or Ebay.
Feb 06, 2011 | Televison & Video
The burner control goes ''pop.''
Your igniter lead is shorted by some foreign object and needs to be cleaned before it kills the spark module.
This usually happens when you have a pot that boils over spilling liquids and solids on the igniter contacts.
Check the igniter area on the side that doesn't pop to locate the igniter tip, then find the exact match to it on the other side and clean it off with a toothbrush and alcohol.
Mar 23, 2010 | Kitchen Ranges
Need to clean the MMI after a spill
did you get a solution for this. I spilled my son's milk in it.
Dec 05, 2009 | 2008 Audi Q7
Keypad spill on Acer Aspire 3613 Laptop
More than likely the pop has gotten inside your unit. you would have to open the unit, disconnect your keyboard, clean the leads and connectors to the keyboard. If the unit was on when this happened the mb may have shorted in which you would need a new kb.
Dec 06, 2008 | Computers & Internet
Pop spilled on camera
I think you can consider this is a water damaged item since water has been immersed into the mainboard which cause sensor failure. Camera internal components were very fragile and I suggest you not open it if you really don't know what is inside unless you have opened it once. I have fixed cameras for my friend before but mostly with part failure not water damaged and I believe your is just partial damaged only. Below is some help links to direct you how to fix your own camera: http://brashear.phys.appstate.edu/lhawkins/photo/camrep.faq.html and other easy way is go to google search URL window or Yahoo and type Casio Digital Camera Service Guides, then they will provide you a lot of links where you can get information to fix your camera. I hope this help.
Apr 10, 2007 | Casio Exilim EX-Z50 Digital Camera
Cell Phones Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
