When I insert batteries into the play laptop, it's getting activated automatically but none of the other keys are functioning including OFF. Able to OFF only by removing the batteries
    Scholar:
  • 181 Answers
Good day.
Maybe the switch of your laptop is damage. This is not a user-serviceable part, there is a need to disassemble the laptop case. Visit your nearest service center for your laptop to be fixed.
Good luck
Tedmac
Posted on Oct 04, 2010
I reinstalled Windows 7 on my Inspiron M5010 laptop. Now I no longer have wireless. The F2 key which normally would turn it on no longer works. I gather that I no longer have the drivers for the top row of...
The function key on my dell laptop was set to the F keys, meaning you have to hit the function key and then an F key to activate the F key. I switched it in the bios so I don't have to hit the function key to activate the F keys. So I would have had to hit Fn+Ctrl-Alt-F1 for example to get to TTY 1. Now since i switched it off in the bios All I have to do is hit Ctrl-Alt-F1 to get to the terminal. But in order to turn off wifi from the F key (for example) I have to hit Fn+F2. It's switched.
Aug 17, 2013 | Dell Inspiron M501R Phenom II X3 N850...
How do I get autotext to work on a Toshiba Satellite Pro?
It will work automatically. Just recheck settings of windows through control panel.
Aug 04, 2013 | Toshiba Computers & Internet
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
Laptop screen is black
There are a couple of reasons that a laptop screen could blank our. The first is that many laptops have the ability to output video to an external monitor or projector, such as for video presentations. In order to save battery life, there is a function key combination that can be used to blank the laptop screen. Most laptops have these "functions" on the F1-F12 keys in blue and there is an "fn" key that must be used with them to activate the function. Look for a key that has a blue "square" with vertical lines on either side of it. This is the Monitor function key. Press and hole the "fn" key, then press the Monitor function key. See if the screen returns. A corrupted video driver could also be the problem. Do you have any display when booting up? If so, try using the F8 key to get to SAFE Mode. If you have a display there, check and see if there are any problems with the video driver, or just reload the driver. The third possibility is the the LCD's backlighting source may have failed. IF this is the case, you probably have an older laptop and replacement is usually cheaper and more cost effective than repair.
Jan 09, 2012 | Acer Computers & Internet
I bought a new laptop including windows 7 and when i insert the prod. key the last letter does not take and it says invalid key. I get sick of this message everytime I open an e-mail . The prod.key...
Contact Microsoft activation at
Windows 7 loadTOCNode(3, 'moreinformation');
  1. Click Start Collapse this imageExpand this image
  2. Right-click Computer.
  3. Select Properties.
  4. At the bottom of this window, click Activate Windows now.
Follow the propmpts and contact and activate by phone, it is the best way. Phone activation takes just a few minutes and someone will come on the line and help if there is a problem.
Jan 05, 2010 | Computers & Internet
How to activate 'green keys' on an Acer from Canada
press the left ctrl and right shift keys to toggle between french and english keyboards
Dec 07, 2009 | Acer Aspire 5315 Notebook
Panasonic DMC-FX10 is frozen
Try a manual reset...remove the battery and the card. Press all the buttons. Insert the card and then the battery. See if that works.
Sep 02, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Projector does not display laptop screen
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the projector checks first for active video during power-up. Highlight Default Source and click the left or right mouse button to toggle
among the options.
Jan 17, 2009 | InFocus LP70+ Multimedia Projector
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Samsung SGH-E250 cell phone
I have a samsung SGH-E250 mobile phone i am unable to change the phone lock code, i hav tried numerous combinations including 0000 and none works. So am asking 4 help does any one know the code or knows how to reset or sumthing oh the phone was made in china
Nov 11, 2007 | Samsung SGH-D900 Cellular Phone
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
