Question about Samsung Digimax S700 Digital Camera
OUTER LENS POPPED OUT
I had the same problem with regard to the lens being frozen with full new batteries and I noted the last post re the advice.
However,
I accidentally dropped the camera whilst the lens was out and frozen and the outer lens has popped out and is now unable to go back in and a beeping noise sounds when I turn it on (obviously telling me that there is a problem with the camera).
I have taken the outer covering off on the screen side thinking that I could get into it and gently move the lens back out but can't seem to get the front outer cover off. Any ideas? Unfortunately the guarentee has only just expired!!
  • 57 Answers
Since you are out of warranty you have to repair it yourself or get a new one. If you can open it and take it all apart it's pretty simple just remember how things look on the inside. All lenses that retract are on a little motor and gears. This is what you have to check and unfortunately it's usually under everything else. If you can get there see if the gear housing is cracked, the gears are in place and not striped and meshing ok. I believe it is going to be the gears. It's not as hard to take a part as people make it seem.
Posted on May 27, 2008
Dsw-370 lens stuck out,tried all 7 on your solution list and still getting "turn power off and on again" on lcd screen. what next? before I GO BUY A NEW CAMERA
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Apr 05, 2011 | Sony Cybershot DSCW370 Digital Camera
My camera lens doesn't opens
Good day,
Regards
15073327
Mar 25, 2011 | Sony DSCW320 Digital Camera
Lens cap error
Good day,
Regards
15073327
Feb 26, 2011 | Nikon COOLPIX P80 Digital Camera
Zoom lens will not extend
Good day,
Regards
15073327
Feb 23, 2011 | Olympus Stylus 400 Digital Camera
Lens error message
Good day,
Regards
15073327
Feb 22, 2011 | General Electric A735 Digital Camera
Lens error / lens won't focus.
Good day,
Regards
15073327
Feb 18, 2011 | Canon PowerShot D10 Digital Camera
Lens error problem..
Good day,
Regards
15073327
Feb 15, 2011 | Cameras
P 7000 lens cover problem
Good day,
Regards
15073327
Feb 15, 2011 | Nikon Coolpix P7000 Black 101megapixel...
I have a kodak Z740. The last time I used it the lens got stuck in the mid way part it did not retract full. after which it just turns off. I guess the batteries get overloaded with a stuck motor. can u...
Good day,
Regards
15073327
Jan 25, 2011 | Kodak EasyShare Z740 Digital Camera
Samsung Digimax S700 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
