Question about Sony DVP-NS715P DVD Player
Sony dav-s880 gives "cannot play this disc message"!
5 Suggested Answers
SOURCE: how do i fix my sony dvd dav-dz230 - 'cannot play'
Hi Neal,
This is probably not the technical solution you are looking for but I have a similar problem but i have tried the following it works for some discs. Put the disc in the tray and press close on the remote and do open and close for a couple of times and sometimes it suddenly starts.
I cannot find an explanation as to why this happens but below are my thoughts:
1. The player is old and perhaps the laser unit position is knackered. 2. For some reason the region code lock in the set is not able to recogonise the code on the DVD. 3. Its possessed!
:) try it and hope it works :)
Posted on Feb 15, 2010
Nomodo4u
  • 863 Answers
SOURCE: My sony DVP-NS725P will not play discs
Run a DVD disc cleaner through it and see if that helps. If not then open it up and manually clean the laser pickup lens. Then give it a go. If that didn't help, then open it back up and replace the optical drive.
Posted on Feb 18, 2010
Testimonial: "Thanks for that had tried cleaning disc before but stripping and cleaning worked a treet"
SOURCE: My Sony RDR-GX7 dvd recorder keeps giving me a
could the problem be a slipping disk?
I had this and cured it by opening up the player and levering off the round cover on the dvd drive, removing the weighted magnet, then cleaning the rubber seat.
Posted on Jul 19, 2011
  • 34153 Answers
SOURCE: Need remote code for Sony DAV S880 home theater. I have Sony RM-V210T universal remote but cannot set it up to work with dav s880. Only PLAY button is working...
You may have to try another universal remote. All remotes do not contain all possible codes.
Posted on Oct 25, 2014
Testimonial: "Yeah, I would if I knew which one...Can't try all possible remotes..."
I have a sony dav-s880 player..b4 it was running superbly but now it can only play a song cd,vcd but cannot play the dvd...its either will eject the dvd or a message will appear cant read.. pls help me...
Sorry to inform you that you have to replace the DVD optical unit ( lens assembly ) .Will cost you about 20$ plus labor. Will need professional help to replace.
Mar 18, 2011 | Sony DAV-S880 System
Can i use a lenscleaner for sony dav-s880?
Yes, put lens cleaner disc in home theater and press play to clean lens.
Jul 08, 2010 | Sony DAV-S880 System
Why is it not turning on?
The answer to this maybe the fan at the back is either blocked with a build up of dust or has to be replaced, I had the same problem and took it out to be repaired started to wipe it down and thought would give it a go after this and it kicked back into life. Hope this works for you. John
Oct 04, 2009 | Sony DAV-S880 System
Can Anyone Help me! I Would like to conect my Sony DAV-S880 Compact AV system to my Hp PC, what is the best option and what cable type do I need to used. Thanks!
Hi there
you can connect this system to your computer in multiple ways. But how you do so depends on what your computer has. If your PC has RCA connections on it then that would be the simplest way but this would leave you with stereo sound. If you have a digital decoder in your computer and a optical out then i would suggest using that. A Optical cable is quite inexpensive and can be bought from pretty much any decent A/V shop.
If you can let me know the model of you PC i can give you exact directions but dont be afraid to play around yourself. I only suggest that you do so carefully.
hope this helps.
Mar 21, 2009 | Sony DAV-S880 System
Remote model [AV SYSTEM 3] RM-SS880 not working :
Need remote code for this home theater. I have Sony RM-V210T universal remote but cannot set it up to work with dav s880. Only PLAY button is working...
Mar 19, 2009 | Sony (RM-SS880) Remote Control
DAV-S880 doesn't accept audioCD
does it say's no disk ,then try some diffrent audio disc,or put small amt of tape on bottom side of disc in the inner hole and try.
Dec 25, 2008 | Sony DAV-S880 System
Connecting audio out from Sony Tritron KD-28DX4OU television
get left and right audio out from your tv and connect it to audio left and right in in your sony dav-s880.
Mar 25, 2008 | Sony DAV-S880 System
Sony DVP-NS715P DVD Player Logo
235 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
