Question about ACCO Brands Staplegun Staples
I have no instructructions and can't work out how to load the staples into my craftright staple gun. how do you load a craftright staple gun?
    Top Expert:
  • ACCO Brands Master
  • 44,225 Answers
Watch the video How to load your staple gun
Posted on Nov 13, 2015
5 Suggested Answers
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
brainyass
  • 242 Answers
SOURCE: LOAD IT
On this model, there should be a spring on the arm. Compress the spring and put the staples in. When you close it, the metal part on the end of the spring holds the staples tight.
_____
I
I
I arm and spring below
I___
___I staples here I_____))))))))))))))))))))))))))))))))))))))))))))))____[___]
Posted on Nov 10, 2008
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
SOURCE: powershot pro staple gun
just purchased a Powershot model 5700m. how do you load the staples?
Posted on Feb 23, 2011
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
CraftRight 3 in 1 Staple Gun
See that shiny steel saddle-looking clip at the "rear" (under your palm when you're using the gun) next to the bottom? Push it inward then down to unlatch it, then pull it straight out. Insert 12mm staples, push that thing back in and latch it again. It SHOULD be a little hard to push it - the long spring is what feeds staples up to the punch piston at the front.
Aug 07, 2014 | Tools & Hardware - Others
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Mar 01, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Jul 07, 2009 | Arrow Fastener T27 Light Duty Household...
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Dec 03, 2008 | Ace Hardware Ace Staple Gun
Powerfast strap gun for romex misfiring
just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
Nov 17, 2008 | Tools & Hardware - Others
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Staple gun
Oct 26, 2008 | Stanley Bostitch Pc2000 Staple Gun Tacker...
ACCO Brands Staplegun Staples Logo
436 people viewed this question
Top ACCO Brands Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an ACCO Brands Tool and Hardware - Other Expert? Answer questions, earn points and help others
