Question about NRS Hoveround MPV 5 - Used Power Wheelchair
My hoveround MPV5 doesn't move. When I turn the power on, all of the battery lights come on and flash in unison. Why is it doing that?
  • 692 Answers
Scottyguy Check your freewheel levers in front of the seat and make sure they are in the drive mode. If they are check your owners manual to see if you have a lock out function for your joystick If you have a lockout then it should tell you how to get it out. Some chairs can be taken out of lockout by pressing the horn button twice as soon as you turn it on. Others use the on/off button pressing the on/off button twice and then turning it on will get it out of lockout and then others use the joystick turn the power on immediately push the joystick full forward until you hear a beep then pull fully backward till you hear another beep then release to the center. With the Hoveround I don't know if they have a lockout or not and how to get it out but the examples I gave you are the only ones I am aware of. If all else fails you can contact Hoveround @ 1-800-964-6837 and ask for tech support explain your problem and hopefully they can help Hope this helps you
Posted on Oct 04, 2010
  • a_raid67 Jan 07, 2011
    well we put it aside for 6mo now after a chg even power will not light up MPVmodel hardley used? so l can.t ck at all without power?
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
May 03, 2017 | Health & Beauty
I just installed the batteries & when I turn it on all the lights continually flash
Either the batteries were wired incorrectly, or the cables are not tight between the control box and battery boxes, or the controller connector is not all the way in. Is the unit in gear?
Apr 28, 2015 | Hoveround MPV5 Electric Scooter - Used...
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Sep 27, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
My mpv5 power indicator says i havea full charge but after about 15 minutes of travel the lighs go to 2 red bars. if i stop and turn it off for 5 minutes it will go to full charge, but for only about 3...
Nothing against hove-round ,but to me it sounds like the problem may be do to a bad cell in one the the two battery's .This will cause an uneven charge which will be a result of the problem that you are having now.Also make sure the two battery's are new, they should have markers on them that say the month and year.Also make sure that your charger is working .when you plug that chair in ,turn it on see if it will move and see if the light are flashing.that will let you know if its reading that its being charged.
when you find the bad battery and replace it and its saying its fully charged and it does this to you again.The last thing it could be .is your motors are going bad the breaks are over loading the power.
Good luck hope i was of some help.
Jan 17, 2011 | NRS Hoveround MPV 5 - Used Power...
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
How can I get a manual for the Hoverround MPV5?
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
Apr 29, 2010 | NRS Hoveround MPV 5 - Used Power...
My mpv5 hoveround has lights that go on, but nothing happens. I have 12 volts from each battery, but the lights just flash.
My father in law has a hoveround and it is in the lock position but we can't remember how to unlock it.
Aug 16, 2009 | Health & Beauty
My hoveround MPV5 will not operate. fully charged battery charger light turns green. the brakes are in run position and when the unit is turned on the charge bar just flashes and the chair will not...
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 14, 2009 | NRS Hoveround MPV 5 - Used Power...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
616 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
