I need to order another remote for my tv. - Televison & Video
  • 8,617 Answers
Www.replacementremotes.com will have the remote you need
Posted on May 28, 2008
Need att uverse remote codes and Durabrand hb2404d tv codes to set up tv?
0185,0188,0184,0183,0180. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 18, 2014 | Durabrand Televison & Video
I have sony tv rm-GA010 controller.for lcd tv. but
Hi, you can order a new RRMCGA759WJSA from Replacement Remotes. or you can order the keypad repair kit from replacement remotes to fix your keypad problem. You need the solution that is sold in the kit to fix the rubber keypad for those buttons.
Nov 01, 2013 | Sharp GA759WJSA Remote Control...
I think I need a new remote control I ordered a new remote that I was told this was an alternate the original was no longer available I order a PLT 3250 remote should I have order a PLT 32 instead the
Have the first remote tested--most shops have a tester--point remote at it and press buttons and it reacts with a flash (the tester) and if remote tests good the problem could be with the remote receiver in the set
Oct 29, 2012 | Protron PLTV-32C LCD TV
WE LOST THE REMOTE,WHAT IS THE REMOTE MODEL NUMBER SO I CAN ORDER ONE TV MODEL (LCT 2060)
Try the website like Remotes.com to order another original remote.The tv back cover model numbers,that all u need.Write it in the box it will provided will come up the right remote.
Jul 10, 2010 | Akai LCT2060 Television
Need code to re sync to tv
The Harmony remote does not use codes. In order to get the remote to work with your TV, you will need to add the TV to your remote in the software. You can download the software at http://logitech.com/myhermony.
Once you are logged in to the software, click 'Add Device' and enter the make and model number of your TV. When the TV is added, click 'Update Remote.'
Jun 05, 2010 | Logitech Harmony 890 LCD Remote Control
Can't get the tv/input button to work on dish remote control with vizio tv. need it to view local channels run off antenna
Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
Oct 19, 2009 | DISH Network IR Remote Control
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Jun 13, 2008 | Coby TF-TV1901 19 in. LCD Television
Direct tv codes
THE CODE IS 11610 AND IT WORKS!!!! :)
Sep 22, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
