Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Fisher & Paykal DD6031 Integrated We have a
Fisher & Paykal DD6031 Integrated We have a double drawer integrated dish washer and the top drawer appears to have partly completed the wash then stopped with some water remaining on the bottom of the drawer. The drawer itself is hard to pull open and I am not sure if the nephews opened up the drawer during the wash cycle. The bottom drawer still has power and works while we are unable to bring up any of the functions on the top drawer. I have turned the power on & off at the wall and no change. Do you have any solutions
  • davelark308 Oct 05, 2010
    Yes it is the Integrated model with the three switches on the upper right front with the middle switch larger than the other two switches while when open there is selections of Heavy, Normal, Fast Delicate, Rinse plus Eco found at the top right.
    The top drawer can be pulled open but is very stiff but there is no sound or lights on the buttons. The botttom drawer works fine.
  • davelark308 Oct 06, 2010
    Thanx for the prompt reply and yes I am always keen to repair myself where possible therefore some guidance and instruction would be great.
  • Fisher and P... Master
  • 3,247 Answers
The fault you have described with the top drawer appears to be related to the lid seal becoming dislodged. However, I am slightly unclear if you can actually open the drawer or not. YOu mention it is hard to pull but you also say you see water at the bottom of the drawer. So I am assuming you are able to open the drawer. This is important otherwise it will become hard to check the problem.
It might help confirm if the lid seal is the problem if you can check which lights are on at the top of the drawer lid. For example NORMAL and RINSE. I am assuming since you have an integrated model there is no LCD display in the front.
If it is a lid seal problem then you may have to call the technician from Fisher and Paykel. It does involve a little patience and mechanical prowess to fix it. There is fiddling with motors etc involved.
You can check the parts out at this site.
Posted on Oct 04, 2010
  • 1 more comment
  • Sam Oct 05, 2010
    If none of the lights on the top drawer are on and it is not responding to the switches then the controller has lost power. This in turn has caused the lid seal motors to freeze and hence the reason why the drawer movement is stiff.
    Controller power is lost if the thermal fuse located in the heater assembly is blown. This is a safety mechanism to protect the dishwasher if the temperature goes too high. Sometimes it can also mean the thermostat became faulty causing the heater to overheat.
    In order to restore the controller power the heater assembly needs to be replaced as the thermal fuse is integral to it. This part looks like this.
    Once the power is restored to the controller then it will pull the lid motors back unless these are out of position which means the seal has to be opened and the motors repositioned.
    Let me know if you want to fix this yourself or call the technician. I can give you some idea of how to access the heater assembly etc but it is not a trivial task to replace. The drawer is very compact and requires a fair bit of effort and patience to repair.
  • Sam Oct 06, 2010
    I can only give you rough guidance as it is very diffcult to visualise words through this media. Also might be slightly different for the integrated model considering it will be harder to detach from panels.
    Turn the power off, unplug power and water connections. Remove all items from inside the drawer inclding the filter plate and the impulse rotor.
    1. get the top drawer out from the housing - remove the plastic pins on each side of the drawer to get the front cover out. Keep a stool next to the dishwasher and slide out the drawer use the stool as support. Retract the side rails to ease the drawer out from the slide rails and rest on the stool.
    2. Unhook the hose support at the back to ease the drawer out further. You will need to get to the base of the drawer to access the heater plate under the wiring cover.
    3. Carefully release the four wiring cover clips from the front lower section of the drawer taking care not to damage them. Release the three clips on the underside of the drawer which retain the wiring cover. Disconnect the fill hose from the dispenser (water may drip).
    Disconnect the chassis harness plug from the electronic controller. Disconnect the heater element harness plug and earth wire from the element plate. Unclip the drain hose cuff from the motor assembly taking care not to misplace the non-return flap valve. Unclip the drain hose, fill hose and the wiring loom from the under side of the drawer.
    4. Unplug the motor wiring harness from the electronic
    controller. While lifting the tab on the locking ring at the base, rotate
    the ring anti-clockwise until it comes free of drawer tabs. Take care not to damage any motor wiring as the locking ring is turned This also releases the motor housing from the locking
    ring. Holding the pump housing on the motor assembly lift the
    locking ring, heating plate and motor clear of the drawer tub. The suction pipe of the drain molding will slide out of the tub drain area.
    5. You may now lift the locking ring clear of the motor
    assembly. This will allow the heater plate and motor assembly to come apart. Be careful of the two large 'O' rings which seal between the motor assembly and heater plate and the heater plate and tub, these and the tub sealing area must be clean and put in the correct place before
    reassembly takes place. Check both the drain cuff 'O' ring and suction pipe 'O'
    ring for deformation and damage. Lubricate and if necessary replace 'O' rings before reassembly.
    6. Replace the heater assembly with new one and follow reverse order of fixing everything back in.
    This is the best instructions I can provide. YOu can always use the bottom drawer as reference if you muck up the reassembly. But I would suggest not to disassemble the bottom drawer as it still gives you full functionality.
  • Sam Oct 07, 2010
    Please do post a comment or a testimonial if you find the instructions useful. Thx,
Lights up wateris on select cycle close drawer nothing happens
I assume you are pressing the "Start" button. I think this model does not auto start.
Have you selected "Delayed Start" by mistake?
Feb 06, 2014 | Fisher Paykel DD24DHT17 Fisher & Paykel...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I uninstall double dish drawers. I can take the drawers out but internal frame seems fixed
It depends on which model you have. The integrated model would most likely have the frame lodged inside the kitchen panels. The freestanding model should simply pull out after removing inlet and drain hose and power connection.
Jan 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on my Fischer Paykal drawer dish washer . This is the flood sensor . It was. tripped when water was splashed in a plug that shares the same Circuit. How do I reset the sensor?
Not sure if the flood sensor will trip if the water is splashed into the mains plug. F1 can also occur if the power to the top drawer has failed. Flood sensor trips when water collects at the base of the dishwasher housing under the bottom drawer.
I think the problem you mention has caused the power to the top drawer to fail due to a spike when the splash on the power plug occured. This is very easy to see. Check if the display on top drawer is blank.
Nov 04, 2012 | Fisher and Paykel Dishwashers
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I remove the bottom drawer of my F & P double drawer dishwasher for mounting into the cabinetry?
I am assuming you have an integrated double drawer unit DD603I.
The instructions for removal and refit of the drawers is available in the Installation Manual. I am able to locate one on the following site
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
You may also need instructions to prepare and fit the front panel of the cabinetry to the drawers which you can down load from
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this is what you are after.
Nov 18, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
486 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
