Question about Brother IntelliFAX 1250M Fax
Intellifax 1450 mc......where to buy blue levers which hold down scanner head. Brother Singapore do not have spares for old machines.
    Scholar:
  • 159 Answers
I have spare parts, just e-mail me smartstuff@telus.net
Posted on Oct 06, 2010
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I have a Brother Intellifax 1250, getting error 81... Other than older than dirt and throw away, can anyone tell me what that error code is?
Well the scanner is gone there is no parts . Brother dose not support that old of unit any more. (sorry) spend some money and get you a new unit. They were a good machine in there day.
Jul 21, 2010 | Brother IntelliFAX 1250M Fax
How to change the drum of my brother intellifax 2830
open the front cover of the machine, remove the toner. the drum will come out with the toner, it's the tray holding it. press the blue lever to seperate them. you can just slide on the new one.
Mar 02, 2010 | Brother IntelliFax-2820 Laser Fax
FAX770 cannot copy
Bad scanner block, no spare parts are available.
Jul 05, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother intellifax 2820.Replaced toner cart tn350.
Remove drum unit. in front of the toner cart. there is ether a green or blue slide lever. move the slide 10-15 times back and forth. make sher the slide is all the way over to one side. reinstall drum & make a copie. hope this works.
Jan 05, 2009 | Brother IntelliFax-2820 Laser Fax
Print only on rigth side. I know it the blue lever. Where can I get parts
I have the same problem with my 1950MC. When I examined the blue lever carefully on the right side of the machine I found that the plastic lever was cracked at its thinnest point. Thus when both levers are locked down that one was not holding the print head tightly enough to print that side of the paper. If I held the print head down manually, the copy printed fine. So if you have this problem, check the blue levers for cracks. The levers are easy to remove and should not cost very much. I recommend that you replace both left and right levers. These plastic parts cannot stand up to very much use without cracking.
Jun 22, 2008 | Brother MFC 1950MC Printer
Fax printing problem
The blue release lever that holds the ribbon cartride may be cracked or broken. The crack may be so fine, that it's not easy to see, so look carefully. Even the slightest crack will cause the ribbon cartridge to fit loosely enough so that the roller is not touching the paper. Whatever side is not printing, that's the lever that you should look at. That's what happened to mine. I was ready to buy a new machine, until I found that solution. To test it, I tried to copy something while pushing down on that side of the ribbon cartridge, and it printed fine--the whole page. I looked more closely at the lever, and found the crack.
Jun 10, 2008 | Brother IntelliFAX 1250M Fax
Printing problem
One of the blue locking levers is broke. the side that is light is the side the locking lever is n.g. open the top like you want to change the film. there are 2 locking levers. right and left. They are different. if you look close you will see a split in the plastic when it locks down. It is not holding down on one side. I think I have the locking levers. One small screw removes the top plate and you can change them. Lawrence
Aug 16, 2007 | Brother IntelliFAX 1250M Fax
Fax machine prints only on left side of page
One of the blue levers that hold the the top of the imaging unit to the printer has cracked. If you look carefully on the side that is not printing and flex the lever you will see a hairline crack. You can buy the levers at an office equipment repair store. You can also try gluing or taping a screw to hold the unit to the frame. What is happening is that the imaging unit is not close enough to the film to transfer the image onto the page. Happens all the time on these units.
Originally solved by Sue O: www.fixyourownprinter.com
Oct 07, 2006 | Brother MFC 1850MC Thermal Printer
50 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
