Question about Vacuums
I have to rewire the plug on a Pfaff Dorina 75 sewwing machine (foot pedal & electrical input. I cannot get it right - anyone can tell me what to connect to which of the three connections in the plug ?
  • 1 more comment
  • brian_vogel Oct 04, 2010
    Your reply does not help me - I have no color coding on the plug & wires.
    The electrical plug has two wires - blue (N) / brown (L)
    The foot switch has the same - blue (N) / brown (L)
    The three connectors in the plug are all brass, spaced: N, empty, L, L.
    My machine is quite old (1980).
    There is a single connector at the back of the machine that connects the power plug and the foot pedal to the machine, using three pins as listed in my previous reply.
    My problem is to connect the foot pedal correctly so that it controls the current to the motor.
    Two wires from the power lead.
    Two wires from the pedal.
    Total four wires into the three connections on the machine's
    connector
  • 1,514 Answers
The colour of the wires differ depending on where you are. If you're in the USA and using 120V system the wiring is
Black (the hot wire) goes to the brass connector, The White goes to the Silver connector and the green goes to the Earth connection.
Posted on Oct 04, 2010
  • 1 more comment
  • Joe Bannon Oct 04, 2010
    Ok to wire the mains plug, hold the plug with the long pin at the top. This is the earth pin but as the machine is plastic it is unused. The blue wire is neutral and goes to the N connector at the left hand side. The Brown wire is the Live and goes to the L connector on the right hand side beside the fuse.
    On most machines the foot pedal has a seperate connector which plugs into the machine and not into the mains plug. Again the blue wire goes to the N connector and the Brown goes to the L connector
    Is the power lead connected to the pedal and what colour wires are coming from the pedal?
    Ok so you've 3 places to connect the wires 2 that are marked L and one marked N. Put both blue wires into the N and put the 2 brown wires into the 2 L connections. It won't make any difference which one goes in which place because when you press the foot switch what it does is join them together.
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
7467S sewing machine beeps four time and won't let me sew
Hi! Probably too late to help the original asker, but I have this same machine and was having the exact same problem. 4 beep error message, but mine would not sew at all. Found this question through a google search, but no answer. But I figured it out! I had left the buttonhole lever down!! (Facepalm) I hope this is helpful to future googlers with a similar problem.
Feb 05, 2014 | Singer 7467S Confidence Stylist Electric...
I am trying to figure out how to move my needle left and right....Just need to shift it a touch...I have a Pfaff 2048
Do you have access to the internet? -- or do you have the operators manual for this machine?
Here is a link to the manual on line-- it is free:
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/faf472aa38aebf31852575fb00745b81/$FILE/exp%202034%20-%202046.pdf
Pages 31 thru 34 tell you that the top right button on the control panel determines the needle location-
Does this help?
Mack B
Jul 04, 2011 | Vacuums
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
I have pfaff 875 hobbymatic and the presser foot ...
I am having the same problem. Did you ever get an answer?
May 21, 2010 | Vacuums
Vacuum is making a burning smell from the motor/fan.
Actually the screws to access the motor on Kenmore canisters are located underneath of the foot pedal that retracts the cord reel, and there's usually also two screws that underneath of the tool lid arms.
You may access the screws underneath of the cord reel by prying the foot pedal off of the vacuum. Simply put a flat head screw driver in between where the foot pedal and the vacuum cleaner meet on the top of the machine, and pry upwards with the screw driver. Once you remove the pedal you'll see the screws and have direct access to the vacuums motor.
If you are trying to access the power nozzle motor, here's a detailed step by step instruction tutorial that will walk you right through it.
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
When a vacuum cleaner smells like something is burning, it can only really be one of two things. Either the rubber belt inside of the power nozzle is burning, or the motor is burning. If it's the belt that's burning, it will be a burning rubber type of smell, but if it's the electrical motor, it will be more of an electrical smell.
If you have any further quesitons, please feel free to reply using the clarification request tool here on Fixya. I'm always more then happy to answer any follow up questions.
If this was helpful, please rate my repair by clicking the thumbs up icons in the top right hand corner of this repair.
Thank you,
Chris J.
GoVacuum.com
Apr 11, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
