Question about Razor E300 Scooter
I replaced new battery but still the scooter runs slow
    Sergeant:
  • 168 Answers
The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
I hope this helps; remember to rate this answer.
Posted on Oct 04, 2010
How to tell if brushes on rascalmob. 388xl need replaced as scooter running slow?
The motor will run hot when the brushes are worn. If the scooter is used daily and runs a lot, brushes could be the problem. They are not difficult to replace.
Sep 09, 2016 | Health & Beauty
I just replaced batteries and the scooter is really slow. Also a rubbing sound from the back but nothing is touching. Any ideas
If the battery is new and fully charged and you have this problem then something is binding in the power train. See if you can disengage the motor from the train to see if it speeds up. If it does so appreciably then that is definitely the problem. Do not use it like that because the slow operational speed of the motor will result in less back emf, & considerably more current consumption resulting in motor overheating, burnout!
If motor still runs slow when disconnected from power train, then something is wrong with the motor. Perhaps the bearings are all gunked up. If some of the windings are shorted out the motor will also run slow and is in need of replacement.
Aug 30, 2015 | Health & Beauty
Why is my scooter running slow?
Hope its this. Batteries fully charged. You should take to dealer. I bent my go lever. I bent it back alittle. There is little switches under the cover, they can moved. Lever is not make proper contact
Sep 28, 2014 | Pride Revo 4 Wheel Scooter
Panther lx4 runs irregularly .batteries are brand new. ride well for 10 minutes after it starts to slow down then accelerate then slow down etc...
Most scooters have only a rheostat to control speed. Over time, the carbon will wear and cause erratic control.
Oct 14, 2013 | Invacare Panther LX-4 Batteries
My scooter is too slow,the battery charges,but it only drives at very slow speed,while going backwards it goes fast.Can you tell me what to do?
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. In the future give as much info about the scooter as possible.
1. Replace the throttle pot and or the speed pot.
2. Sometimes even batteries that take a charge are not strong enough to run the scooter. Have them load tested at an auto parts store to make sure. If you have bad batteries that will make you scooter do what you say it's doing. Don't forget your reverse speed is only 1/2 as fast as the forward speed on all scooters.
Good Luck
Tim
Apr 30, 2011 | Health & Beauty
Brake seems to stick on causing battery to run down
Sounds like you have weak batteries or a bad brake. You can measure the brake resistance at the connector between the front and rear halves of the scooter. The brake is good if the resistance measures between 30 to 65 ohms.
You should load test the batteries to see if they are good. It takes battery power to run the motor and release the brakes. Weak batteries will cause the brakes to drag and the scooter to run slow.
A new brake costs about $70 and new batteries start at $40 each.
If you do not have a beep fault code, nothing has burnt out yet. I would have the scooter checked out soon by a qualified technician. Hope this helps.
Jan 08, 2011 | Pride Mobility Products Go-Go Elite...
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Feb 07, 2009 | Pride New Mobility Victory XL 4 Wheel...
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Razor E300 Scooter Logo
1,927 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
