Question about Samsung SyncMaster 753S 17" CRT Monitor
How to open moniter circuit - Samsung SyncMaster 753S 17" CRT Monitor
  • 11,361 Answers
SIR... MY LG 700E MONITER START OFTER 20 MINUTS OF SWITCH ON... WHAT SHOULD I CHEACK IN CIRCUIT OF MONITER...??
This is fault within the main mother board, can be related to the power supply or the processor secttion but is sure a lowering of value in capacitors.
If you are able to open the monitor and use a Hair dryer, the spot will be identified immediately as a heating in sections of the power or the board will switch on the monitor and thus confirm the area which can be pinpointed with a closer heating.
replace the suspected capacitors with the correct value , insert into the PCB with the correct polarity.
Sep 13, 2011 | Computers & Internet
Moniter is not on . i checked the power is comming to the moniter. no picture no lights, screen is not on i mean moniter totally dead.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 04, 2010 | Hanns.G Corporation JW-199DPB 19" LCD...
Moniter power light blinks purple.
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 30, 2010 | Smart Modular SV3170A
Moniter has flickering and moving stripes
You may have power supply failing, but try this monitor with other PC first, if it still does not work then you will have to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 30, 2010 | Acer AL1717 17" LCD Monitor
Pavilion F1703 17" LCD Monitor: my moniter lose disply but sound is there it happe...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | HP Pavilion F1703 17" LCD Monitor
Lcd moniter locking up with blank screen. On/off button will not work
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&lc=en&dlc=pt&cc=pt&lang=pt&man_lang=en&product=3686798
May 15, 2010 | HP w1907 LCD Monitor
Moniter's menu option gets automatically selected whenever i open my moniter screen
arpanpallar, If you are certain that pc not causing problem, then hp internal "switch-mode-power-supply" could be the problem. Noisey DC source will cause very strange things to occur on screen!! You or technician will need to look for common visual signs of bad capacitors on the circuit board. Do some reading in my and other CCFL back-lit lcd monitor tech's fixya profiles. 12fixlouie
Mar 12, 2010 | HP Computers & Internet
Computer beebs on start-up, moniter shows black
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 27, 2010 | Dell Dimension E310 PC Desktop
Samsung SyncMaster 753S 17" CRT Monitor Logo
98 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
