Question about Whirlpool Refrigerators
I have an Estate side by side fridge, and the front of the wall dividing the fridge from the freezer is very hot...almost too hot to touch. Any suggestions?
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
This is s sure sign that either the condenser fan is not running OR that the condenser in the bottom rear of your refrigerator is plugged up with lint and or pet hair. Remove the fiberboard cover from the lower back of your refrigerator and clean the condenser and the condensor fan area.
Just unplug the unit while doing this and be careful not to bend any lines.
If you need parts information or more assistance I will need your model number.
Thanks for Choosing FixYa.
Kelly
Posted on Oct 04, 2010
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Wall dividing fridge from freezer is very hot to the touch
You either have obstructed coils (lots o dust) under the fridge or the fan that is supposed to draw air across them has ceased to work. Check the coils and clean as necessary, and check the fan. Maybe you will get lucky and find something caught in it. If the fan is not working, leave the back cover off the fridge and put a small window or box fan back there until you can get the fan replaced. The fan will keep the fridge running for you in the meantime.
Jun 29, 2010 | Refrigerators
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Wall that divides the freezer and fridge section on our side by side is hot.
In the wall between the doors is a heater to prevent it from sweating. It's actually just behind the front of the divider.
Feb 13, 2010 | Kenmore Refrigerators
Side by side. Front edge of divider between fridg
There is a heater there that reduces condensation. If you have a switch that has energy saver mode, that would turn it off
Sep 04, 2009 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
