Question about Frigidaire Dishwashers
The buttons on the dishwasher won't push and let me change settings. it will only let me push start and run the last cycle ran
  • 901 Answers
Try completing the last cycle till end. Check the user guide and there
will be a master reset operating procedure. You may have to operate
the keys in sequence as mentioned in the guide manual.
Posted on Oct 04, 2010
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Brand New Whirlpool Dishwasher won't start, can't change program eiether
Make sure the dishwasher door is firmly closed, press and hold the start pause button for about 5 seconds, this will clear the cycle, The try selecting a wash cycle and push start.
See if this helps.
Mar 04, 2012 | Whirlpool Dishwashers
Our dishwasher continuously flashes "CL"
Hi trrhodes,
I believe the CL you are getting means "Child Lock". Under normal circumstances there should be no activity at all on your machine.
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jacques
*If you found this solution helpful, please rate it
May 23, 2011 | Dishwashers
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
I used the "rinse only" cycle on the dishwasher a little while ago. I've never used this cycle before. After dinner I tried to start the dishwasher, but no other buttons on the panel respond except the...
Try un-plugging the dishwasher (check for cord under the sink) or turn off the breaker to it to re-set the control board. If this does not resolve your issue you may have a defective key panel.
Jun 18, 2010 | Dishwashers
When i push the normal wash button and it changes to another cycle after a few minutes then wont run at all just freezes up some water was in the basin modelmdb9100
What you're describing as changing to another cycle may be the dishwasher trying to display diagnostic information. For example, if you ran a Normal cycle and it appears to switch to Light Wash, check to see if the "Clean" indicator is also lit. This would indicate a motor fault, which would explain why it appears to "freeze".
May 12, 2010 | Maytag MDB9100A Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Kenmore dishwasher
needs a new control panel/ touchpad assembly very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 27, 2007 | Dishwashers
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
80 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
