Question about E-Machines Computers & Internet
To take recovery from comupeter witout disk tre button whist
    Guru:
  • 468 Answers
Inorder to restore the computer back to factory restore you can try Alt+F10 (As soon as the computer restarts keep on holding "Alt" key and tap on F10), it should comeup with the recovery console and follow the onscreen instructions.
Thanks and regards,
Anil.B.R
Posted on Oct 04, 2010
I lost my recovery disk or restore disk for my sony vaio VGN-FE660G. If anyone could direct me in the right direction to get them.
There are no System Recovery CDs included with the computer. The recovery data required to return the computer to the original, factory-installed condition is included on a special partition of the hard drive. Follow this procedure to create the Recovery Media Kit (a set of Recovery Discs), which can be used to restore the recovery partition and return the computer to the original, factory-installed condition.
  1. Ensure all open programs are closed.
  2. Ensure all network connections are disconnected.
  3. Ensure all peripheral devices are disconnected.
  4. From within the VAIO Recovery Wizard application, in the Create Recovery Discs window, click Next.
  5. Under Create Recovery Discs (Step 1 of 3), click to select the option to use either DVD or CD media.
  6. Click the Next button.
  7. At the Insert a blank... dialog box, insert the appropriate disc.
  8. Click the OK button.
  9. Insert a new disc when necessary as instructed.
  10. When all the disks have been created, click the Finish button.
Dec 30, 2013 | Computers & Internet
Sony XPERIA ION cannot switch on...
Reset tre battery by holding vol up+power button untill it vibrates tre times. If that does not work root i true flashtool for xperia.
Jan 09, 2013 | Sony Xperia Ion LT28 Black 16GB Android...
Factory rest witout a disk
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jun 09, 2012 | Toshiba Satellite L455D-S5976 Notebook
Deleted printer by mistake, how do i add printer again. witout the disk( mispalced disk)
Click to start button and open the window of control panel.
From control panel select printer and faxes .
Under the printer tasks select add a printer and it will being watched a dialogue box.
Click to next.
Attach the printer to the CPU and select local printer attached with the CPU and click next.
To install printer click next.
Select needed port to install printer and then click next.
Select your printer HP Deskjet.
Then it will automatically installed.
Apr 11, 2010 | HP Deskjet F340 All-In-One Printer
Want to restore HP Pavillion 505 N computer back to original
To do a system recovery without recovery disks (not all machines can perform this without recovery disks) press the power button and immediately keep tapping the F10 button until you enter the recovery console.
If unsuccessful, you will need to boot using the recovery disks that came with the machine.
  1. Place the first disk in the 1st CD tray (some machines may have multiple CD/DVD drives) and start up.
  2. Start the machine and immediately press ESC button to enter BIOS
  3. Select the drive the recovery CD is in
  4. Press Enter
  5. Once the machine boots off the recovery disk it will provide several options
  6. Press R for a standard recovery
  7. Press F for a "destructive" recovery (will wipe out and format hard drive)
  8. Press Q to quit
Once you've made your selection, the recovery process will automatically proceed. It may ask for additional recovery disks which have more software.
NOTE: if you are currently able to boot into the machine prior to recovery you should go in and back up any pertinent files. Both recovery options will wipe out personal files.
A link to this information has been provided below. Best of luck.
Greg
HP Recovery
Nov 04, 2009 | Computers & Internet
The menu screen appears witout me pushing buttons
The contact for the menu button may be stuck. It's at least five or six years old and may be on its last legs. If the menu button has shorted out, it may be more cost effective to replace it during Xmas sales. Check Amazon or Newegg.
Oct 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My sansa mp3 play wont turn on
Tried this? 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 05, 2009 | SanDisk Sansa e260 MP3 Player
How do i reset my mt2700 back to factory settings witout recovery disc
If yous system did not come with a recovery disk, then it is possible there is a recovery image of windows residing on the D:\ drive partition of your hard drive. If this is the case, when you boot up the computer and it's on the black screen, you should be given an option something like "Press F10 for Setup" . If you press F10 you will have options on how to recover the PC to factory defaults.
Please rate in case the solution was of help to you. Let me know if it resolved or not.
Thanks
Oct 17, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
