New os I have a motherboard WT70-EC and I am putting on a new OS and it keeps rebooting itself after loading windows can yanyone help me!!
    Sergeant:
  • 336 Answers
The system will reboot after the installation of the boot sector in order to install the rest of windows. Just let it reboot and it will continue to install. If this is not the problem you are experiencing tell me all of the details of what is happening and I can help.
All The Best,
RCF
Posted on May 27, 2008
Should I remove Windows Vista on my Compaq Presario Laptop? It is installed as OE but I amm told Microsoft does not support it anymore
For the past few upgrade cycles I have upgraded by purchasing the best value new computers with the OS installed. I connect the old computers to the new via a home network. The newest has Win-7 and is much faster, however, the learning curve is steep getting all the old stuff to work. So for some stuff I still rely on the older machine. This has given me the best results.I still use Vista and XP, but if you feel compelled to upgrade do to security reason I would follow the following outline.
  1. Back up on an external USB drive all important documents. You must do this if not Murphy's rules will apply and it can be a train wreck!!
  2. Down load Acronis from Western Digital website. Make a Boot disk.
  3. Create a clone copy of your master C:/ drive on an external USB drive.
  4. Purchase a same or larger internal PC master C: drive "It must be a Western Digital for the free version of Acronis to work"
  5. Replace current drive with new.
  6. Using Acronis boot disk boot up and connect USB drive
  7. Clone new drive from USB with vista OS using the Acronis boot disk and confirm all is well
  8. You now have a way to go back. Your original drive still has the Vista OS with all your Junk and the new drive should have the same.
  9. Using the new drive go to the Microsoft website and go for OS seven. Keep your clone copy of the vista OS on the USB drive in case the seven blows-up during install.
  10. Retain the original C: drive with the vista OS in case you get into difficulty with the new drive.(mark the drive with date etc)
I have successfully done this for computers and keep a drive loaded with a known good OS for the day it all goes bad.
Sync-toy is the backup program that I use to keep everything up to date.
Hope this helps?
Mar 09, 2016 | Compaq Presario C700 Series Laptop...
How to change os
Hi
To change OS - Operating system, the easiest way if by upgrading your operating system from Windows XP to Vista or Windows 7 or others.
Here how it works. Open your computer and let it run your windows operating system until it finished loading the windows display. After, put the OS installer on your CDROM to upgrade it either to Vista or Windows 7 and it will run the upgrade process. Follow the procedure and it is easy to follow. It will reboot for 3 times and finish itself. And its done.
I hope it helps you.
Jan 13, 2011 | LG 22" FLATRON LCD Monitor
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
Computer will not start up After Windows splash screen Computer reboots itself. gives options for safemode, lastknowngood, start windows normally. but when selecting any same thing happens computer...
Hi alizae68,
It sounds like your Windows files are corrupt. My suggestion is to use your recovery disk if you have one, if not use your OS disk and repair windows. They way you repair is to put the disk into the CDROM, and when the computer asks if you want to boot to the CD press any key, Press a Key! Then Window will load certain files, and do it's thing. Go past the request for acceptance using the F8 function key, and then it will look to see if you have an existing Windows program, at that point you can choose to repair the existing windows, Don;t install new or it will create a new location to install to. It won't erase your files. From XP SP2 on windows always creates a backup folder of the old or original OS and stores it for you to access.
After it repairs your system, it will reboot and you should be fine.
Good Luck
Mark
Feb 17, 2010 | Dell (E210882) Motherboard
GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Oct 26, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
I bought used d600 and need to format it
hi,
you can do the following.
D drive can be formatted from windows itself. open my computer. right click and click format and follow instructions.
But C cannot be formatted from windows as it contains files that would be in use.To format C insert the windows(OS) CD and restart. change boot option. this can be done by pressing F4 or F8 while the system starts. now cahnge boot device to cd. now follow the instructions to load the OS(windows) and install it in C. Select quick format or format and you are done. All previous data and the OS would be deleted and the drive would be formatted and the new OS would be installed. If You want to keep your previous files, select keep files system intact while the procedure is being run.
Dec 30, 2007 | Dell (04U621) for Latitude D600, Inspiron...
Computers & Internet Logo
David Payne
David Payne
