Question about Dryers
Service manual for an LG DLG2532w dryer? - Dryers
    Genius:
  • 1,044 Answers
Posted on Oct 04, 2010
eagle338
  • 4889 Answers
SOURCE: HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Posted on Oct 15, 2007
SOURCE: LG DRYER DLG2532W GAS
Orange county, CA
Thanks Engineergeek and Sreechowl.
I have the same problem with LG DLG0452w. The Global Appliances service technician said the flame control is bad. It need to be replaced and want to charge me 550.00 for the service. After I read your post and I follow the instruction to reset the thermostat. It worked. Fixya!
Global appliances service is a liar. Nerver do bussiness with them.
Posted on Jan 11, 2008
SOURCE: LG DLG2532W Gas dryer problem
I just purchase my LG front load gas dyer and am wondering what types of problems to expect and what people are doing about it....
Posted on Feb 19, 2008
MNTECH
  • 1543 Answers
SOURCE: HOW DO I GET TO
Disconnect power. Remove the two phillips screws at the 5 and 7 O'clock position behind the door (in front of the lint filter area). Remove the (3) phillips head screws on the bottom side of the L shaped part on the back edge of the dryer's top. Stand in front of the dryer and use the palms of your hands at the sides of the top to sharply push the top back about 2 inches. Lift the dryer top off. Remove screw at each top corner of control panel. Remove plastic control panel by releasing plastic tabs along the top edge. (be careful of the sharp edges) Swing the control panel up on top of the dryer. Remove (4) phillips screws at the top of the dryer front. Unplug the light and door switches and you will be able to remove the front panel. The limit switch is on the front left side of the gas burner chamber (behind the gas valve). It is about the size of a dime, with two wires to it. Push the pin in the center of it in. Reassemble dryer. Improve your vent or you'll be doing this repeatedly. (eliminate flex ducting, use rigid aluminum pipe, as few turns as possible, as short as possible, and clean the lint out of the pipes. Make sure the end termination is one that has a few louvers or better yet, a flap which can move a full four inches, not just two inches)
Posted on May 03, 2009
localwonder
  • 6784 Answers
SOURCE: I need thermostats for LG Gas Dryer DLG2532W in houston TX
Hi, you can order your replacement thermostat parts at the link below.
CLICK HERE
Posted on May 21, 2009
Tip
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE.
Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf
Also applies to:
DLE5911W
DLE2511W
DLE5932W
DLE5932S
DLE2532W
DLE0332W
DLG5911W
DLG2511W
DLG5932W
DLG5932S
DLG2532W
DLG0332W
on Apr 29, 2009 | LG DLG5932W Gas Dryer
DLG2532W dryer not heating up. check filter light is on, but all filters are cleaned.
We have the same dryer and the check filter light always comes on at power up but goes off when starting. Is yours still not heating? as I see you question is a little old now. let us know.
Tim
Jul 05, 2010 | LG DLG2532 Gas Dryer
Model DLG2532W no heat, lint not an issue, circuit breakers OK, gas service OK. What could be the issue?
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 14, 2010 | LG Dryers
LG DRYER #DLG2532W IS WORKING BUT IS MAKING A LOUD NOISE,WHAT CAN IT BE?
Something was able to get passed the lint filter and into the blower wheel.
Using a flashlight look down and to the left inside in filter housing spin the drum by hand both ways and see if you can see anything.
If you can remove the object.
Some times you can get the object with tape on the end of say a 18" long dowel rod.
If you cant remove the object you will have to call for service.
Jan 14, 2010 | LG Dryers
CLICK HERE
May 21, 2009 | LG Dryers
DLG2532W - LG Gas Dryer - Not spinning/working
COULD BE A DOOR SWITCH A THERMAL FUSE A CONTROL BOARD OR A MOTOR
YOU'LL PROBOBLY NEED TO CALL FOR SERVICE
Feb 22, 2008 | Dryers
(Gas Dryer ONLY)
Requirements.
connection.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
Dryers Logo
235 people viewed this question
Top Dryers Experts
