Question about Biostar U8648 Motherboard
Please help me
I need the manual with specifications U8648 cause I need up to 1Gb in Ram
    Guru:
  • 1,342 Answers
Go HERE and download the documentation for the U8638 they are the same except for the processor speeds.
Takes up to 3gb of ram.
Posted on May 27, 2008
I have intel 101 Ggc Mother board and intel pentium D processor , i was using 756MB ram (512+ 256MB) RAM. But after i brought 1 GB ram and Used it instead of 256 MB Ram the system started restarting...
There is a chance that you have faulty RAM module. If computer is stable on POST (until Windows boot-up) I would suggest to use some testing tools to test that RAM with your motherboard. There is a good program called MemTest. You can find it online if you search Hirens Boot CD. Download it, burn image to disk, put 1GB RAM into motherboard, start-up PC and boot from CD. Then you'll search for Memtest program. I would suggest to leave PC for at least 6 hours for testing to find out if it's faulty or not (better to leave for 24 hours).
Aug 17, 2011 | Intel D101GGC Motherboard
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
RAM memory expand modules
sir..thanks for more information abut your unit..the best memory u need is 1gig DDR1 or (X2)times two 512Mb DDR1 PC400 memory..Thanks and Good Luck...^_^..Have a nice Day Sir..
May 17, 2009 | Compaq D51C PC Desktop
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
I need your help me
You need to upgrade your memory modules to a bigger size, check your motherboard manual for supported memory speeds.
You can also look at your current memory be removeing it from the socket and see what it reads on it. Its either DDR memory or older SDRAM. I beleave your maximum memory is 3 GB
May 27, 2008 | Biostar U8648 Motherboard
Biostar U8648 Motherboard Logo
78 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
