Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Error Code C-8102 The ADF is currently not
Error Code C-8102 The ADF is currently not available
0x05 epson error code
What us the result of the error? what are you doing to produce the error?
Sounds, offhand, like a driver failure of some kind (ADF??)
Jul 19, 2015 | Epson WorkForceR WF-3540 All-in-One...
Konica Minolta bizhubc552 error c8102
Here is the error code definition: C8102 Turn around pressure welding alienation trouble
•During a pressure motion being performed, the reverse roller sensor (PS7) output does not change from H to L. •During a retraction motion being performed, the reverse roller sensor (PS7) output does not change from L to H. Further research yields this possible fix, since this model is in the same family as yours: http://www.copytechnet.com/forums/konica-minolta/89213-konica-minolta-bizhub-452-error-code-c-8102-a.html
Apr 06, 2015 | Konica Minolta Office Equipment & Supplies
Which code on button of an ADF showing error
do not understand? what code? ADF error? what error?
Jul 07, 2014 | Konica Minolta DiALTA Di183F Copier
How do you fix error code c55
Here are the steps they recommend in the users manual for a c55 error.
5.1.11 Optional communication related service call
[C55] ADF I/F error
[F11] ADF I/F error
(1) Check if the connector CN71 on the ADF/RADF board is disconnected.
(2) Check if the relay connector between the ADF/RADF board and the PFC board is disconnected.
(3) Check if the connector CN246 on the PFC board is disconnected.
(4) Check if the connector pins are disconnected and the harnesses are open circuited.
(5) Check if the conductor patterns on the ADF/RADF board and the MAIN board are short circuited
or open circuited.
(6) Replace the ADF/RADF board.
(7) Replace the MAIN board
Jan 05, 2013 | Toshiba e-STUDIO166 Printer
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
IN CANON IR2270
you have the wrong ADF installed on your machine this is the error code E490-001
if this is the code then you have the wrong ADF on the machine ther is no E049-001 code so i figured it was a E490
May 20, 2009 | Canon imageRUNNER 2270 Copier
Error Code : E000400-0100
The problem is with the adf. You can try to reseat the connectors on the adf controler PCB. Only do this with the copier turned OFF. If that does not work you will most likely need to replace the adf PCB
Feb 16, 2009 | Canon imageRUNNER 5000 Copier
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
2,007 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
