Question about Hampton Bay (261025) Dual Mount Ceiling Fan
Need blade screws - Hampton Bay (261025) Dual Mount Ceiling Fan
  • 377 Answers
They do not list the blade screws specifically at this URL:
http://www.eceilingfans.com/
but there is a phone number you can call to see if they will sell them to you. I would personally go to Lowes or the Home Depot and pick them up.
Posted on Oct 04, 2010
I ordered a new blade because the original one's
No one can help you without the make and model number of your shaver
Apr 25, 2013 | Health & Beauty
I need the screw that hold the blade on the saw. its the model # cs185cf
Fixya does not sell replacement screws. Your saw probably uses a flanged cap screw with a standard thread.
Apr 07, 2013 | Kraft Tech Krafttech 12 Amp 7-1/4"...
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How do I put the blades back in my model 059750 005 000 trimmer
I have the same model. Actually, they're quite old. If you don't have replacement blades already, you can find them at Sally Beauty Supply ( sallybeauty.com for a location near you ) for about $20 for this model. The replacement blade may not be available online, but my local store has it available for purchase. You may find it available at your local beauty supply.
Remove the two screws that hold the 2-piece blades in place. Remove the blades and take note of how they are situated together. Both have flat sides that slide together where the teeth meet. Your replacement blades should be arranged in the same manner when you put them back on the trimmer. First place the smaller blade onto the clip. This is best done by aligning one of the diamond shaped hole with one of the flat prongs, then pushing the balde towards the side to help snap the other prong into the other diamond shaped hole. Once this is securely in place put the larger blade on so that the smooth surfaces touch each other and the holes for the screws are lined up. Replace the screws securely but do not tighten it. Do the same with the second screw. You should just barely be able to slide the larger blade around with some effort. You will need to do this to properly align the blades together. The teeth of both blades should never meet at the tip. The smaller blade should be about 1/16 - 1/8 of an inch away from the tip of the larger blade and should be evenly spaced all the way across the width of the blade. If you have this set properly, go ahead and tighten one of the screws. Check the spacing of the blades again to ensure they have not moved. If they have, you just need to slightly loosen the one tight screw and re-adjust. Tighten the screw back down. If all is aligned propperly, you should be able to tighten the second screw without any problems. Don't forget to lubricate the blades with the proper oil. Check you local beauty supply store if you need oil. That's it. They are now ready to trim.
Dec 06, 2010 | Health & Beauty
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Do not know how to replace a blade, no instructions
The blade is clamped to the saw with two screws. Unscrew both screws slightly. Pull down on the blade to remove. Blade holder may have a pin that engages blade. You may need to giggle the blade back and forth. Install new blade inreverse order.
Sep 11, 2009 | Skil Saws
How to repair my hair trimmers?
I am a retired hairdresser and it sounds like one of three things or a combination. Your blades may be worn (dull) and need replacement , it may need to be oiled,the blades could be "misaligned" and need to be adjusted. You do that by removing the two screws holding the blades on, remove the blades, while you have them off, clean out any built up clippings in there and then put the blades back on. BEFORE you tighten down the screws make sure the "teeth" from the blades are lined up so the bottom blade teeth can be seen BETWEEN each top blade tooth. NOT directly on top of each other. Now tighten the screws. urn the clipper on and add a drop of clipper oil (no substitutes) onto the running blades. That should do the trick.
Jul 20, 2009 | Andis Outliner® II 04603 Hair Trimmer
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Security screws on bottom of coffeemaker
I took a small (cheap) slot screwdriver with a blade just wide enough to fit into the wide part of the screw. I then took a hacksaw to the center of the screwdriver blade. This works best if the hacksaw blade is fairly thick. The idea is to remove enough of the center of the screwdriver blade so that the screwdriver can be inserted into the screw allowing the hacked out area of the screwdriver blade to fit around the stupid center post of the screw. The screws on mine weren't that tight, so I could turn the screws without twisting the screwdriver blade.
Dec 08, 2007 | Krups Aroma Control 229 Coffee Maker
Hampton Bay (261025) Dual Mount Ceiling Fan Logo
27 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
