Question about Uniden TRU9466 Cordless Phone
Line problems We have two lines coming into the building. When someone calls the main phone line number it will show up on the second line. So line one will not receive the call. How can I fix this problem. I have two different numbers, one for each line. Thank you
I disconnected phone cord from base unit and then reconnected the phone cord after a few minutes and then it worked. I have no clue why that solved my problem.
Posted on May 31, 2008
We have 4 RCA 25425 phones in our office. When someone calls, all phones ring. We only want main line to ring.
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
Jan 10, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
We are unable to receive calls properly, we are having problems forwarding calls that do come in to other extensions and when we dial, it's like a pause before the numbers show up and then the call finally...
Do you have analog lines? There is a wait time for the number to be recognized, before sending out to the phone line.
Do you know the release and model phone system?
Jan 12, 2011 | Avaya Lands Phones
Static on second line of four line system
Oh, o.k the static on the line could be either from the line card in the system,the wire between the system and where the lines first come in or the line before it comes in the building.if it was the line card, the static should show up on the other lines in that card.With that in mind the easiest thing to do would be to call your telco provider and report the line problem. They'll test the line up to the building to see if the problem is there. Beyond that the next step would be to have your wiring checked by your telephone installer. Hopfully they be able to resolve the problem.
Jul 22, 2010 | Lucent PARTNER18 Corded Phone
How do I change the caller id number for my phone
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.
When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you wish to program OLI on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
Press the next key 5 times (bottom right arrow) .
The display should say OLI #.
Press the Chng key and enter in your DID number,
Press ok when finished.
Press the release key when done programming.
Oct 05, 2009 | Nortel T7316E 2-Line Corded Phone
We have an AT&T system with 4 lines and several MLS-12D phones. Two of our 4 lines are not working. If someone is on the main line, additional incoming calls do not roll over to the other lines. This...
Changing programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#301"
the display should say line assignment and station:
enter in the station you want to program the line on.
the display will then ask for the line number to program
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say Lxx and 2 not assigned
enter 1 on the dialpad (assigned)
repeat procedure for remaining sets
enter feature "00" when finished
Sep 01, 2009 | AT&T Lucent MLS-12D Phone
How to establish extensions?
The extensions start at 10 , and if you press the speaker button and hold it for a second or two it will show the extension number in the LCD display . If you do not have any phones with a display you have to find it by pressing the intercom button and try dialing the extensions one by one .
Jun 19, 2008 | Comdial Impact 8012S Corded Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Uniden TRU9466 Cordless Phone Logo
128 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
