Question about Sony Ericsson Walkman W810i Cellular Phone
Starts up but display is blank
Hi, i recently reset my phone and set everything back to default. since then its stopped working, when i switch it on i get a phite screen then after a few seconds i get a orange walkman screen but no icons, i recon i have completely ruined it. can anyone help me. please. i love this phone and this is a complete nightmare for me....
cheers
    Scholar:
  • 173 Answers
Did you get it wet?
Posted on May 29, 2008
I can't get my console to display with the hdmi cable, but it works with my ps3 and the console outputs fine on a different tv. I took it back to the store this morning and they tested it and it worked...
It sounds like a resolution problem. Make sure your XBOX is reset to default settings. Use your other TV for this.
As the console starts, press and hold Y while holding the right trigger. This will reset the video settings to default, and restart your XBOX. Connect it to you HDTV and adjust the settings according to your TV type, and the MAX resolution. (I.E. if you only have a 720p TV, then you cannot select 1080p; you will get a blank screen.)
The steps are as follows:On your console, go to My Xbox, and then select System Settings.Select Console Settings.
Select Display.
Select HDTV Settings.
Select the resolution that is supported for your HDTV.
Select Yes to confirm the change.
Note If your HDTV does not support the selected option, the screen goes blank. If the screen does not reappear within 10 seconds, the console switches back to the original setting.
Aug 19, 2011 | Microsoft Xbox 360 4GB Console with Kinect...
I hae come back from holiday to find my printer is'nt working. Its a Kodak ESP3200 Series and I have had about two years. The on/off switch is on all the time and the LCD screen is blank and nothing...
Try to reset your printer to factory default settings. But before you do that, I'd like you to do this first.
  • Open the printer access door.
  • Remove and install the print head two times.
  • Close the printer access door.
  • Wait until the printer is ready to use.
if this won't work.
reset all defaults to the factory default settings:
1. Press Home. 2. Press "arrow down" to select Printer Settings. 3. Press "arrow down" to select Reset All Settings, then press OK. 4. When you see the message, "This will reset printer settings to factory defaults," press OK
Hope this helps.
Jun 17, 2011 | Kodak Office Equipment & Supplies
My nokia 6300 device have hanged with blank display ,now my question is , what can i do?
You can try restore
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
Feb 20, 2011 | Computers & Internet
My nokia 6300 device were hanged & my device have started with blank display .what can i do
You can restore
Take a full backup.
First Try it:
If
On Sybmian phones:
Hard reset
Remember.
Hope this helps.
Feb 20, 2011 | Nokia 6300 Cellular Phone
How do you reset an LG Rumor 2?
Hey buddy,
For soft reset, simply switch off your phone. Take off the battery from your phone for a couple of minutes, then put it back in and slide up the back cover.
Follow the instructions below to hard reset your cell phone.
Menu button > go to settings/tools > settings > More > go to security.
Enter your security code > select Reset/Erase > then reset > Press OK.
If you do not know your security code, press 0000 or contact your network service provider. You can alternativley get the code from this web site -
http://www.unlock-zone.com
http://www.mobileunlockguide.com/mobile-phone
Let me know if this helps. Thanks!
Dec 09, 2010 | LG RUMOR Cellular Phone
My phone is showing an error message "3d010017"
hi , To fix the error , please reinitialize the software of ur mobile . i will give u the step
    1. While in standby mode, press the left soft key for Menu
    2. Select Settings (9)
    3. Select Reset Settings (8)
    4. Press the OK button to check the box(es) for the following:
      • All: Phone, Display, and Sound settings will be reset to the default values
      • Phone settings: Only the Phone settings will be reset to the default values
      • Display settings: Only the Display settings will be reset to the default values
      • Sound settings: Only the Sound settings will be reset to the default values
    5. Press the left soft key for Reset
    6. Press the left soft key for Yes to reset the handset
    7. Enter the password, using the keypad, default password is "00000000"
    8. Press the left soft key for OK to reset the handset
    For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 15, 2010 | Samsung SGH-t219 Cellular Phone
Hi there, everything seems to be working but there doesn't seem to be a signal going to the TV. Am just about to try using a HDMI cable. Do you think this will help?
What I did was initally hook up both the composite (R/W/Y) cables and the HDMI and switched between TV inputs until I found the display. Once I had the display (mine was on composite) I went to the settings, then display, and switched it to HDMI input. The screen went blank and I switched to my HDMI TV input and saw the display. I unplugged the composite and it was good to go. I also had to hold my finger over the power button for a few seconds when turning it on - I believe it resets the display to default, but it worked. Good luck!
In the event that it gives you a hard drive error shortly after, it's nothing to worry about. You won't lose anything and it will take a few minutes to run its course. Just make sure you never turn it off from the back of the system first, always shut it off via menu options.
Respectfully,
Don
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
Component out doesn't work on Denon AVR-3805
You can try resetting the unit, it is a procedure that can make things start working again. Be aware that it will put all settings back to factory defaults, and you will need to go thru and set everything back up again. If it does not work, then you most likely have a component failure that will require serious electronic troubleshooting and this would be best done by a professional.
Here is the reset procedure.
1. Turn power off with the main power switch on the front display, this should make the red led go out. There are 2 power switches on these Denon's. One is a bigger switch and is used most often, the other is a small mechanical switch that is normally left turned on at all times.
2. Hold down the "Direct" and "Pure Direct" buttons together (both at the same time) and while holding them down you turn the power back on again with that little power switch you just turned off.
You should see all the lights in the display light up and then it will turn on to the default setting which, if my memory is right, will be the tuner at it's lowest setting.
Then go thru and reset everything back the way you like it and need it. Make sure that all the video inputs are properly set for each function so you are not trying to get a composite signal out of a function that may be set for S-video or something like that.
Hope this is some help for you.
Dave
Nov 08, 2008 | Denon AVR-3805 Receiver
Lenova N100, Screen Blank
can you push the f2 or delete key when first starting computer, If you get a bios screen you want to reset the computer to factory settings just follow the directions in the bios to reset to factory default, You may also want to try the Blue FN key lower left hand side, and the f8 key at the same time let me know if that works for you
Dec 24, 2007 | Lenovo 3000 N100 0768 - Pentium Dual Core...
No Service No time display
press menu....settings....advanced.....reset to defaults.....reset settings(reset all will delete your sim contacts) But this is just to reset your phone but most likely this is not your problem, your phones most likely defective or water damaged
Dec 09, 2007 | Nextel i830
Sony Ericsson Walkman W810i Cellular Phone Logo
63 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
