Question about Kenmore 64852 Electric Dryer
My idler pulley seems to be one piece with no way of placing the belt through it. does the idler pulley have to be removed from its bracket and reinstalled with belt around it
  • Kenmore Master
  • 7,482 Answers
No the pulley does not have to be removed.
This video will show you what and how to do it.
appliancehelponline.com/dryerbeltvideo.html
Please rate me
Posted on Oct 04, 2010
Replacinga kennmorefrontloaderdryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 21, 2012 | Dryers
Kenmore 110.731102100 Gas Dryer replace belt
Jun 03, 2012 | Kenmore Dryers
Roper gas dryer wont tumble
Jun 03, 2012 | Roper Dryers
How to fit a belt
Jun 01, 2012 | Whirlpool Dryers
How to replace a belt on a dryer
May 27, 2012 | KitchenAid KEYS750LQ Electric Dryer
The dryer wont spin around but it heats up
May 27, 2012 | KitchenAid Dryers
Belt is loose around the dryer drum
May 19, 2012 | Roper Dryers
How to install a dryer belt
Feb 11, 2012 | Kenmore Dryers
Timing belt replacement
Disconnect negative battery cable. Disconnect power
steering reservoir, and remove reservoir bracket.
Disconnect wire harness bracket for Data Link Conne
ctor No. 1. Remove generator and generator bracket.
Remove ABS actuator. Raise and support vehicle. Rem
ove right front wheel. Remove right engine
undercover. Remove power steering drive belt. Sligh
tly jack up engine and remove right engine mounting
insulator.
Remove spark plugs. Remove crankshaft pulley. . Remove right engine mounting bracket.
Remove No. 2 timing belt cover. . Temporarily install crankshaft pulley with pulle
y bolt. Set No.
1 cylinder to TDC on compression stroke. .
Loosen mounting bolt of No. 1 idler pulley and shif
t pulley toward left as far as it will go to reliev
e belt
tension. . Temporarily tighten idler pulley. Remove cranksh
aft pulley and No. 1 timing belt
cover.
If reusing timing belt, mark direction of rotation
on belt. Also place match marks on belt and camshaf
t
pulley. . Remove timing belt from engine.
NOTE:Always turn crankshaft clockwise.
Mar 18, 2010 | 1997 Toyota RAV4
Open Questions:
My Kenmore 80 series dryer (64852) develops a buzzing sound while drying. Functionally it works just fine. However, after about 20min (this varies) of run time the dryer will usually begin to buzz. The buzzing seems to come and go for a short while and then becomes more constant. Then about 10min (give or take) before the dryer shuts off, the buzzing usually stops. It doesn't seem to matter what setting the dryer in on. (e.g. "Timed Dry", "Automatic Moisture Sensing") Often times when the dryer begins buzzing I can turn the dial back a bit and the buzzing usually stop for a short time. But it seems to pick up with the buzzing again before the dial reaches the same point where it began the first time. Also, because the buzzing remains fairly constant, and I get the impression that the thermostat is cycling things off and on like it should, I don't really think that this is an issue related to the heating element. Although I've been known to be wrong before. As far as I can tell it does have something to do with heat though, because the buzzing only seems to start after the machine has had time to run and warm up for a while and then stops during the last 10min when I assume the machine would be cooling down. Also, I keep the "End of Cycle Signal" in the OFF position all the time. When I have turned it on in the past it sounds distinctly different from the noise it make while drying. One more thing. The buzzing doesn't sound like vibrating parts to me. Thanks for any help you can give.
Oct 30, 2010 | Kenmore 64852 Electric Dryer
Kenmore 64852 Electric Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
