Heating & Cooling Logo
Posted on May 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Filter Cleaning - Carrier Heating & Cooling
Anonymous
Level 2:
Champion:
  • Expert 254 Answers
  • Posted on Jun 02, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
254
Questions
Helped
135616
Points
402
Depends on what type of filter you are referring to. If it is a fabric type filter media these are throw aways. If it is an electrostatic filter you should buy a spare. Wash one use it for 30 days then replace with the spare. Vice-Versa. These need to completely dry before they are put into use.
2answers
How to clean the air filter of an NE router?
Wash your HEPA filter with warm water and allow it to dry if your model specifically states that water cleaning is safe. You can also soak your filter in hot water if it is extremely dirty. Clean non-washable, permanent HEPA filters using a vacuum to remove dust and debris.
Front loader continues to beep& not spin after cleaning filter
I just had the same issue with a Samsung FL'er and indeed my filter was super clogged. Cleaning solved the problem (you checked X2, right?). I also did a hard reboot by unplugging the washer but that was before filter cleaning, so may have been incidental and no real effect.
I presume your issue started after running a "filter-clogging" load so perhaps a blockage has occurred elsewhere in the plumbing.
I have the KAWS700GQ washer with a self cleaning filter. My dark clothes are now covered in lint. How can I clean the filter?
go to
www.youtube.com/kitchenaid_washing_machine/how to clean the self cleaning filter
www.ask.com/
www.about.com/
www.wikipedia.org/
/how to clean a self cleaning filter for a KAWS700GQ
go to www.kitchenaid.com/service/how to clean the self cleaning filter.
Resetting Filter status after cleaning filter
MAKE SURE THAT THE LID OF THE FILTER IS PROPERLY CONNECTED SOMETIMES THESE DEVICES ARE
BUILT WITH SWITCH FILTER
2answers
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
HOW DO I GET FILTER Problem with the Microwave Ovens HOW DO I GET FILTER OUT WITHOUT YOUR TOOL. HOW SO I USE CLEANING TABLETS? AND GRINDER ONLY WORKS PERIODICALLY. MOSTLY BROWN WATER?
I am a little confused as I don't ever remember a microwave oven with brown water a filter and cleaning tablets!
1helpful
Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
Cleaning the filter
the filter is on the back of the machine ,you will have to take the back off filter at the bottem
had to do this a few times gets easier after a few times
49helpful
2answers
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
