Question about Maytag MSD2456G Side by Side Refrigerator
Water leaking from freezer compartment and ice maker not working properly
I'm having multiple problems with my Maytag Plus MSD2456GE side-by-side refrigerator......
The water leak from my freezer may be the same situation as the others I've read about, but I'm also having trouble with the icemaker.
I've noticed that the water actually comes from INSIDE the back of the freezer compartment, from some sort of grate. The leaking seems to happen during the defrost cycle and as many others have said, it pools up in the bottom of the freezer (forming a massive ice block) and then some of it pours out onto the floor from the bottom of the freezer door. Is there a blockage in the drain line?
This has been going on for some time now. It all started when I came in the kitchen one morning to find a floor full of water, all around the refrigerator. I opened up the freezer and icicles were covering the entire freezer compartment!! It looked as if the icemaker had sprayed water out (no telling how many times). I had been having problems with the icemaker for some time. Most of the ice cubes were hollow, as if the tray wasn't filling up enough. Then, when it would dump the ice, the little "fingers", as I call them, wouldn't go all the way back down into the tray because there'd be some drops of water that would freeze on it and obstruct the proper functioning. When this happens, it's as if it has been cut off by the wire lever arm. You can push the "fingers" down into the tray, thereby breaking the ice "balls" off by force, and the icemaker will start working again, even though the tray still doesn't fill up with enough water. Since we cannot afford to get the fix-it man out here, I just shut the thing off and stopped using it. But I'd sure like to get it working.
I linked these two problems together because I thought they may be related. I recently took the (inside) water filter cartridge off and replaced it with the (factory) filter bypass plug, thinking that maybe the filter wasn't letting enough water flow into the ice tray. I haven't turned it back on since doing that, however. I'm scared that it'll spray my freezer again and I'll have a flood in my kitchen!! Anyway, I also did this hoping that the water leaking onto the floor would stop. It seemed to have stopped for several days, then a couple of days ago, I noticed it's back to the same old thing. Could the hollow ice cubes be from: poor water pressure from the supply tubes -- a sensor (for water level in the tray) -- a timer (for water level in the tray)? And the ice obstruction on the "fingers"??
Let me tell you.....I am at my wits end with this supposed "nicer-much-more-expensive-than-I'm-used-to" model of refrigerator!! If you can lend ANY ASSISTANCE WHATSOEVER, I would be eternally grateful.
  • 1 more comment
  • Anonymous Jul 03, 2008
    exactly the same problem, plus the wire bar got wrapped around the ice dispenser. I bent it back into shape and re-intalled it, but now you have to push it down manually to get it to dispence the ice. Now it appears the water leak has shorted something out. The door is always hot to the touch.
  • Anonymous Aug 06, 2008
    ice has been froming at the bottom (3/8 inch thick at back side of compartment with it thinning out some towards the front). Water has been puddling up on the floor right where the door opens. I turned off the freezer compartment and with towels soaked up the water as the remaining ice thawed. Then I turned freezer back on. 12 hours later, everything seems fine, so I now have put several gallons of water in containers in to see what happens next. I'm hoping the line mentioned above that might have been frozen up has thawed. If not, is it a job for a pro or can I get it right?
  • 4Babs6 Jan 05, 2009
    When freezer is on 'self defrost' mode, an Ice Block forms at the bottom of the freezer. Once it starts melting, my kitchen floor is wet. Help - need a solution..............
  • 481 Answers
  • the water(in the bottom of the freezer) is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • and
  • the icemaker problem
  • it could be that the water valve is slowly leaking water into up to the icemaker and freezing before dripping out of the tube. then when the icemaker turns on the water to the icemaker it is partially blocked by the ice and sprays water all over instead of gently falling into the icemaker.
  • if this is the case then changing the water valve on the back of the machine and defrosting the fill tube behind the icemaker should fix this problem.
Posted on Jul 14, 2008
Freezer works ice maker leaks water into freezer compartment. Refridgerator cranked up all the way cold and throws warm air not cooling food it is 5 years old
sounds like its set to high on the cold selection, and it needs to actually defrost , setting the freezer to colder much of the time will worsen the problem, if you can unplug it for a day and let the machine defrost ( deice) then it will be able to actually function better, Ice causes the functions to not be able to work properly. the ice maker leak could be caused by the limit switch being frozen , remove the tray and make sure that the unit isn't clogged with ice, if it is,, leave the tray out while you have it unplugged, and it too will fix itself once the ice is removed
Jul 20, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
I have a maytag plus fridge MSD2456GE the icemaker is not filling with water what could it be?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 28, 2010 | Maytag MSD2456G Side by Side Refrigerator
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
I figured it out. When the water filter gets old and plugged up, not enough water flows into the cube trays. You can fix the ice problem by replacing or just removing the filter. (The filter really isn't necessary unless your water comes from a well or some other undesirable source.) The filters cost about $40 from Sears, but you can find them on ebay for under $30 including shipping.
Jan 27, 2009 | Refrigerators
Water leaking from freezer compartment and icemaker problems
I can help with the puddles on the floor. Most likely your freezer drain is plugged. This site and others on the internet helped me solve my problem. Take off the back shroud and empty the freezer compartment. Take the screws out of the lower grate at the back of the freezer compartment. You can get the lower panel out with a little effort. The freezer coils are exposed. Below them is a kind of small light metal trough with a drain hole in the middle. You don't see it at first because it is covered with ice. I used a hair dryer to melt the ice. When it melted enough I removed a thin cake of ice to expose the drain. The drain was still frozen until I poured hot tap water in the trough several times. Inside the back of the refrigerator on the right is a little rubber coupling that connects the drain tube from below the coils and metal trough at a right angel to a tube that runs to a drain pan on the low left side at the back. After taking the coupling loose so I would not damage it, I put a thin screwdriver down through to finally unclog the drain. I recoupled the drain line, wiped up the floor and put everything back together. Everything works. Saved at least $150 and it only took about an hour. Oh, yes, the small hex screws on the back and the inside grate use the same small socket screwdriver. A lot handier than using a pair of pliers.
Jun 01, 2008 | Maytag MSD2456G Side by Side Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
1,371 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
