Question about Zanussi FJS1225W Front Load Washer
E10 problems i keep getting e10 code half way through the wsh ive checked all the solutions in manual the pipes are clean the filter is clean and no kinks in pipes help
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on May 29, 2008
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Washer keeps flashing e10 and that code is not listed in my manual
it can be 3 things,either there is a cold water flow restriction/the drain hose is too low/or too far down in the drain pipe/or theres an over suds problem
Feb 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Feb 04, 2010 | Electrolux Washing Machines
Drying
The E10 error code means - not filling water.
The problem could be because of clogged filters on the water inlet line or a malfunction inlet valve.
Also there is still some water inside accumulated so please do check the filter for blockages.To avoid other errors check the outlet valve and the filter as a precaution.
Good luck with the machine.Please do rate my solution.Also do post comments for further help if needed.
Apr 11, 2009 | Washing Machines
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
My front end loader washer keeps saying e10 error
E10- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
Usually due to debris trapped in the drain pump (pebbles/coins/hairgrips etc) jamming it. Clean it all out including all pipes.
Please rate fixya if we could solve your problem.thank you.
Dec 11, 2008 | Washing Machines
E10 error message
I have had the same problem on an AEG. The problem it refers to is that there is not enough water entering the machine. Either the water pressure is too low or there is something blocking pipes/filters. Hope this helps
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Hotpoint ultima 1200
Kirsty - There could be an item like a hair clip Jamming the pump impeller. Or then it can be only a blockage in the filter or in the waste pipe or if the waste is connected to your sink drain check that the blockage is not there - either in the end of the pipe or in the sink connection.
Try disconnecting at the sink, holding the waste pipe into a bucket see if it will pump out then. If it does then the problem lies in the sink plumbing - if not then it lies in the machine.
If the pump and filter and hoses are definitely clear you could have a Pump, PCB or wiring fault. Hope this helps.
Mar 12, 2008 | Washing Machines
E10 error and fabric softner
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Jan 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FJS1225W Front Load Washer Logo
64 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
