Question about Palm Zire 31 Handheld
Double Screen on Zire 31
When the PDA is turned on the screen is duplicated. One and 1/2 rows ofe icons normally displayed on the left side of the display are duplicated on the Right
  • 3 Answers
Have you tried a reset? You might have to open up the case (carefuly, i broke the cables by accident on mine doing that)and wiggle the cables around, As they could have shaken lose over time. if all that fails, you might have to do a hard reset or re-instal the software.
Posted on Oct 19, 2008
Display is too large for screen
Hello Dr. Bankert and thank you for contacting Fixya, I will be glad to assist you.
What you need to do is turn off a setting within the System Preferences > Universal Access feature within your Power Mac G5.
To do this, you need to click on the Apple menu icon, located in the upper left corner of your screen. When you do click on that menu icon select System Preferences from the drop down menu:
Then go into System Preferences and look for the pane (icon) entitled Universal Access 9_16_2012_10_06_45_pm.png
• Click on the Universal Access and you will see this view:
Under the Seeing tab, make sure Zoom is turned to Off
This should bring your enlarged screen back to its normal size.
You can now also click the Show All button located at the top of that window (on the left side) to return back to System Preferences main window.
From within System Preferences, select Displays and try selecting a lower resolution like 1280 x 1024 or 1024 x768 for example and see if selecting one of those resolution settings helps to reduce the size of your display window.
Please let me know if any of these simple recommended steps help.
If you have more questions, I will be glad to assist you further.
Regards,
-The MacTechTrainer
Sep 10, 2012 | Apple Power Mac G5 Desktop
Desktop screen
try booting in safe mode and see if the screen displays properly.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the 1 inch black space then your video card might be going bad or you might have a virus infection. If the Borrowed monitor displays ok then your original monitor is bad.
May 29, 2012 | Dell Inspiron 530 Desktop Computer...
How do I connect my Compaq Presario 62-231 to a wireless network?
Check the sides and front of the laptop to see if there is a wireless switch to turn on. If so, turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 16, 2012 | Computers & Internet
How to turn on wireless capability vpcl137fx
Have you looked on both sides of your computer and at the front for a Wireless Switch that has to be turned on? Once the switch is turned on, normally a set of keystrokes can toggle the wireless on and off. Normally you would Press and Hold the FN function key then hit the correct F1 through F12 key that toggles the wireless. The correct F1 thru F12 key will normally have the wireless icon )))) or it will have the icon of a tower with the wireless signal )))) around it. Also when you toggle the wireless by keystrokes the screen displays Wireless On or Wireless Off.
Apr 20, 2012 | Sony VAIO VPCL137FX/B Notebook
Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
To calibrate your Streetpilot c-Series touch screen, follow these steps:
    1. Begin with the unit turned OFF and unplugged from a power source.
    2. Power the unit ON, continue to hold the Power button for 1 minute.
    3. A screen will display instructing you to Press dot in the lower left corner.
    4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
    5. Your unit should now function normally.
I hope this helps. Please rate my reply. Thank you.
Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
I have a tomtom xl 330-s and cannot get a screen in english
To change the language to English on this unit do the following
1) First make sure the unit is fully charged as you will need to proceed with a reset of the unit.
2) Once the unit is fully charged - press and hold the on/off button for at least 15 seconds until you see it perform a restart.
3) Once you are sure it has restarted turn the unit on normally and you will see a screen filled with text. This will probably not be in English so tap the little tab in the right hand lower corner of the screen to proceed.
4) Now tap anywhere near the centre of the screen which brings you to a main menu.
5) You will see 6 icons on this screen. Tap the one right in the centre of the bottom row.
6) Now Tap on the right arrow icon (which is on the righthand bottom of the screen) until you see a screen appear with an icon with three flags. The three flags icon will be in the top left hand side of the screen.
7) Tap the three flags icon - you will see English appear in the options list - tap this and chose Yes to confirm.
If you follow this procedure exactly the unit will display English language screens from here on in.
Hope this helps. Many thanks for using FixYa.
Dec 29, 2009 | Tomtom XL 330S GPS Receiver
It is not aligned with the keys or letter or icons
Try a screen calibration. To recalibrate your c-Series touch screen follow these steps:
Sep 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
To perform a soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
To perform a hard reset
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
Palm Zire 31 Handheld Logo
121 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
