Question about Kenmore Elite 45986 Front Load Washer
Dishwasher not cleaning dishes right , hotwater ok.. water level ok.
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
SMS60M18AU/03 why dishes are not cleaned properly.
If your dishes aren't getting clean, first make sure you load dishes with enough room between them.
Try running the hot water in the sink for a minute before starting the dishwasher. Using a thermometer, test the temperature of the water by filling a glass from the sink-the temperature should be from 110 to 120 degrees. Also, use the right amount of detergent for your water's level of hardness. Poor cleaning could also be due to a mechanical problem with your dishwasher. Those problems often involve parts that move water into, around and out of the dishwasher tub. A faulty detergent dispenser or heating element can affect cleaning results as well
Oct 25, 2017 | Dishwashers
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp252 not rinsing clean
Hello
Clean the internal parts of the dishwasher. Use a clean wet cloth and wipe down the inside including the racks and the sprayer arms. Remove the upper arm by unscrewing the center bolt. Clean both sides before replacing.
Check the water pressure. The dishwasher requires inlet water pressure between 20 to 120 psi. If the water pressure in the line is too low, proper rinsing will not occur.
Check the water temperature. The dishwasher performs at optimal levels with 120 degree water. Check the hot water heater for needed adjustment.
Use the right detergent. The dishwasher requires detergent designed specifically for dishwashers. Other detergents will leave spots, residue or food on dishes.
Set the machine to the proper cycle. The dishwasher offers a variety of cleaning cycles. Select the appropriate cycle for the type of cleaning required.
Load the dishwasher properly. An overloaded machine will result in dishes not being cleaned thoroughly.
Sep 12, 2011 | Dishwashers
Dishes constantly come out dirty.. What temp should the water be while the dishwasher is running?
Supply water temperature should be above 120 degrees F for effective cleaning. Run hot water from your kitchen sink (your dishwasher should be tapped off the hot water line near your sink faucet) right before you start a dishwashing cycle to make sure it's as hot as it can be when the dishwasher begins filling. Also, during the wash cycle the heating elements at the bottom of the tub may turn on and warm the water further even if you select a "No Heat Dry" option causing a noticeable shot of steam to escape if you open the door during a cycle.
Note: I recently had a problem with our dishwasher (Frigidaire FDB834RFS0) causing dishes to come out dirty and the detergent dispenser to be left with undissolved detergent. Our problem happened to be caused by a partially clogged strainer in the water supply valve. (I would imagine Whirlpool most likely has some kind of filter/strainer in its water valve as well.) When the supply valve was commanded to open for some time, I noticed the water level in the tub would barely be visible below the lower spray arm. After cleaning out the strainer (required removing and disassembling the water supply valve) the water level was noticeably higher -- almost at the bottom of the float or about an inch below the heating elements. Our dishes and the detergent dispenser are now clean.
If your water supply is ok, I would next check to make sure your spray arms do not have any plugged holes and that they rotate freely. Also, use a good quality detergent and a rinse aid. We prefer liquid Cascade and Jet Dry. We have had problems with old, stale, or really thick liquid detergents and by getting a fresh jug have solved the dirty dish dilemma.
Make sure to clean out the filter basket at the bottom of the basin below the lower spray arm occasionally as it can clog and cause the pump to starve due to lack of water. If the pump can't get a supply of water to pump to the spray arms and nozzles, your dishes will not get sprayed evenly and you will end up with them being poorly cleaned.
Hope this helps you out...good luck!
Nov 18, 2010 | Whirlpool Dishwashers
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Aug 05, 2009 | Thermador DW44Z Built-in Dishwasher
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
Fdw20 hotpoint
run the water at the sink till its hot before starting the washer some lines will run cold for about a gallon before the hot water gets to the outlet depending on how far away the hotwater tank is
Feb 15, 2009 | Hotpoint 24 in. FDW60 Free-standing...
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
Kenmore Elite 45986 Front Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
