HOW To Make MY TV WORK ON MY COMPUTER ? - Computers & Internet
  • Rinoo Kumari Oct 04, 2010
    That is a very vague question to ask in today's world. Please specify the make of the TV. Does its manual say that it can be attached to the computer? Whether an picture tube TV or an LCD or what TV is it.
    Novelist:
  • 155 Answers
Hi
Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card.
Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV.
Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals.
Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the TV.
Posted on Oct 04, 2010
Why will my computer not work through tv
Heidi we need a little more information but I'll give a little background here for you so we know what you're trying to do with your TV.
First TVs don't run computer programs so running a computer game on your TV only works if you have a device like a Play Station system to "run" the software. Many TVs these days can be used as Computer monitors but the TV has to be compatible for his usage and have the right ports for instance to connect your laptop/computer to the monitor.
In either case, the TV only acts like a monitor so your computer programs won't run on a TV.
If you have an older TV, there may an interface you can buy that will let your older TV act like a monitor for your computer. You'd have to look up your model TV and see if there is such an interface for it.
Hope that helps.
Nov 29, 2015 | Televison & Video
Tip
Trying to connect computer to LCD TV and get no signal?
Hi.
If you are trying to connect computer to LCD TV and get no signal, as a first thing do the following:
Double check cable and connection. If possible test different connections. Try using VGA, DVI or AV, depending on availability on computer and TV.
Ensure that Video drivers on computer are properly installed, and that the video adapter is working properly.
If you are using a laptop, ensure that you do not need to use a function button to enable the external display, this is pretty common on laptops.
If you are using a desktop, go to display properties, find the windows where you get the picture of two monitors, and ensure that both monitors are enabled.
On Vista try also using the 'Identify Monitor' button on Top. It is located on same properties panel as the two monitor, the main Display Property windows. From the same window you can also modify display resolution, as explained later.
If still no luck, then it may be a problem of synchronization between TV and computer, in that case try the following.
  1. Turn off TV.
  2. Disconnect TV power cord.
  3. Restart computer.
  4. With Computer already on, plug back and restart TV.
....If that does not work.
On computer, go to display properties.
First try changing computer resolution. The TV max resolution may not be available on computer. In that case try lowering down to the smallest 16:9 resolution available on computer graphic settings (usually LCD TVs are 16:9), and if that does not work, set resolution to 800x600, just to test (picture proportion will be distorted, or you get squared box on a 16:9 TV).
If that does not work, open Display Properties. In Display Properties access Advanced, and then Monitor settings (XP). On Vista choose Personalize in control panel, then Display Settings, and go straight to Monitor Settings, in there again go to Advanced.
Under the advanced monitor settings you will find a tab called monitor, in there you find the monitor frequency. Try setting this to 50Hz, if that does not work try 100 HZ, that is the output frequency of your TV. If you get unsupported frequency, revert value to normal.
on Jan 17, 2010 | Televison & Video
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
Aug 16, 2012 | Vizio SV421XVT 42 in. LCD TV
Computer vga cable/ sansui tv problem
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Nov 01, 2011 | Sansui HDLCD1908 19 in. LCD TV
I want to view my computer through the tv monitor
The computer will need to have its video setting changed to work with the TV.
Check the LG TV Owner’s manual for video settings that will work with your TV.
After the settings are made in the computer, make sure your computer will output the video stream to an external monitor (TV) by using a cord from the computer to the TV.
Good Luck.
May 17, 2010 | LG 32LG30 32 in. LCD HDTV
I plugged in the VGA cord from my computer to my television
Most likely your current resolution isn't supported by the TV. Before you plug your TV up to your computer, set your desktop resolution to 1024 x 768. This is the standard and is supported by most if not all flat screens. If it doesn't work on this setting try 800 x 600 or 1280 x 768. One of those three should show up. If no resolutions work, then there is something wrong with the TV. If other monitors work on your computer then the computer is just fine.
Nov 06, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Element LCD TV owners - Using the VGA port may crash your TV!
I bought two of these tv's and they worked fine,I hooked up a computer to both of them and blam smelt smoke in one and the other wont come on either. The computer takes them out. It is a common problem with this TV.
Nov 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Getting windows media to work with tv tuner card
its is due to the older tv tuner card drivers doesnot supports for windows mediacentre try to update driver if not change for new tv tuner card which supports mediacentre.
Feb 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
