Question about Whirlpool Duet GHW9150P Front Load Washer
Door will not shut
Have a wirlpool ghw9100lw1 and door will not shut (wont latch), is it the door lock bad, because the latch on the door looks ok. Thanks
  • 1 more comment
  • turn Sep 06, 2008
    I cant close the door so that it latches. It wont lock? I also njoticed water in thye drum.
  • smytennis Nov 23, 2008
    My door also will not latch. The handle is broken and missing. I'm not sure if I need a new handle or if there's a problem with the latch mechanism. Can anyone help?
  • tina816 Nov 30, 2008
    I have same proble. It shows Error one, not lock, then the machine started 'be be', but actually the door has been locked. How can I get it fixed?
    Genius:
  • 1,073 Answers
If the stike on the door is not broken then it is the door latch
Posted on May 27, 2008
My Gibson Oven oven door will not shut because lock mechanism wont retract?
You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
Jul 27, 2016 | Ovens
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Truck wont lock shut
truck? you ment TRUNK.
some latches can be closed, with open door or trunk.
what you do is trip it.
look at lock and fiddly parts and it goes click..
look at the latch, is the actual latch close with open trunk. yes, BINGO
Oct 08, 2013 | 1992 Acura Legend
Door wont stay locked to run a load
You have a faulty door latch assembly and it will need to be replaced. Here is the part you need.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
Volvo door locked but open so wont shut
ok ,try this,first unlock the door with the poweer locks then get a screw driver,what u do is where the pin in the door jamb would hit the door latch on the door put the screw driver between the two claw like parts that move inward on the latch and pull the door handle like you normally would and then pull the screwdriver towards the car at the same time,the two claw like pieces should rotate away from eachother and the door should close now,hope this helps
Aug 31, 2009 | 2001 Volvo S60
Door locks won't let you shut the doors
Any possibilities of coats, clothing brushing against dooor and INADVERTANTLY latching them closed ? OK heres how to open the latch. Make sure door lock is in the UNLOCK position. With one hand , lift and HOLD up, OUTSIDE door handle, while taking your pointer finger and flipping open the latch on the side of the door. VOILA Hope this helps
Apr 12, 2009 | 2000 GMC Safari
Chevy Blazer door wont close....
Not sore if you have the answer or not. Here it is. MANUALLY place interior door lock latch in the UNLOCK position. Now LIFT UP outside door handle as if opening. While holding it up with your finger ( no prying ) lift up closed latch. Now you should be able to close your door normally.
Apr 01, 2009 | 2002 Ford Escape
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
When you start a cycle the washer fills then turns then sounds as though its trying to empty the door lock light flashes and 2 other display lights flash
It means your door is not shutting or latching
Check for debris and nothing stopping it from shutting
If not replace door latch(some parts lists call it door switch)
its most likely not actuating so it wont advance to the next part of cycle.
if not latch could be bad control board, id try latch first is cheaper and more common
May 02, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
299 people viewed this question
Dan Webster
Dan Webster
Sal De
