Question about Microwave Ovens
I have a frigidaire stove range model number fgf366eca,stove wont turn on and screen says error code on it.
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: Error code F-14 when using
Read the following blog, it describes Frigidaire's F14 error code:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/47659-frigidaire-stove-displaying-f14-error.html
Although your model differs from the one in this blog, the error code will be the same as far as symptoms go, and should clue you in as to what to check, clean, etc.
Also, here is a pdf that describes this fault, also:
manuals.frigidaire.com/prodinfo_pdf/Springfield/316904402.pdf
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 30, 2010
Electric frigidaire stove model:RE-38S serial :61CD4495 oven wont heat. checked;continuity,cord,wiring and outlet all was good. how do i fix this problem?
can not say as do not know if it is a conventional stove oven or a microwave oven . I would call a local repair service
Sep 13, 2017 | Frigidaire Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
My frigidaire gas range is beeping without stoping. I dont have a code to follow. The stove has been off. I unplug it for 24hr. plug it in then after 10hr plugged started the beeping again. Now is...
Hi
The issue is with the control board that is bad and should be replaced. Before replacing you can also try to take it apart and blow some air with a hair drier on the board, if the issue returns then replace the board. Hope this helps...please post back for further assistance.
Daniel
Jun 15, 2011 | Frigidaire Microwave Ovens
NEED A OPERATION MANUEL FOR A TAPPAN GAS RANGE MODEL#TGF328GSF
The manaul for the Tappan gas range, TGF328GSF, is available from the Frigidaire site: http://www.frigidaire.com/manuals ; then enter your model number. The direct link to the manual is http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316417139en.pdf . Tappan, Electrolux and Frigidaire are all lines within one company now.
I hope this helps.
Jun 14, 2011 | Microwave Ovens
How do i fix an f30 error code on my frigidaire range? it only beeps when i try to turn on my oven... and shows f30
Sorry to read about your problem, I hope this helps you out.
You have a shorted keypad membrane.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Microwave Ovens
Manual for Frigidaire 95CC-2689 stove top oven
Frigidaire has a page dedicated to getting you in touch with a manual
but check to plate on your microwave to make sure you have the right model number or you will get a null answer
Dec 03, 2010 | Microwave Ovens
Our microwave (CFMV156DCF) wont heat or defrost but when you shut the door the light comes on and the turn table turns. The fan and light buttons also work. Do you know how this can be fixed? Thank you.
You probably have a bad door switch or door switch mount.
Our file on door switches is here.
The full service manual for this model is at our site here.
You can order parts by entering your full model number or part numbers here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 01, 2010 | Frigidaire FMV156DC Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
F5 Sensor Error?
The failure code list says to replace your Electronic Oven Controll. Contact a Frigidaire parts dealer and check the price and availability.
You will need to give them your make and model number.
Buckle up! It may get expensive!
Good Luck!
Feb 27, 2009 | Frigidaire PLMV168 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
