A pin code does not existed on my router. How do I find it?
    Novelist:
  • 177 Answers
Hi friend,
If you turn the router upside down, you will see a six digit number that is the pin code.
Regards
Chiranjeet
Posted on Oct 05, 2010
What is the 8 digit pin code of TP-LINK_87524C?
The pin code should be printed on the router itself. Each one is different.
Oct 18, 2014 | TP-LINK Computers & Internet
Hi, I got a tp-link 8901g, but no pin code exists behind the router. Only there is a P/N on its pocket with 10 digits, while I need a 8-digit pin for configure my wireless network. What should I...
If you are configuring your wireless network for the first time there should be no pin required, if there is it should be listed in the manual of the device. If you received this router second hand then you will most likely need to perform a factory reset on it to remove any passwords the previous owner may have set. The default login to the router to access all of the router configuration is user: admin password: admin. To factory reset the router you need to hold the reset button with a pin/paper clip while powering the device on and continue holding it for 15 seconds after powering it back on. This should wipe out all configuration and let you back to stock parameters where you can access the router at 192.168.1.1 and use admin/admin to access and reconfigure your wireless settings from scratch.
Oct 13, 2013 | Computers & Internet
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.
The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.
Here is the link for the Owners Manual for your router..
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Hope this helps..
Nov 03, 2012 | Encore ENHWIN3 Wireless Router
I have a wireless G broadband router. I've had it for quite some time and i dont know where the pin code is or the disk the router came with. how do i find the pin code without the two?
The pin code is normally found on the label on the bottom of your router but it's not mandatory to use it. You can reset your router back to factory and google it's default ip address and it's default password depending upon your brand of router. I would search for D-Link Router default password, default username, and default IP address. On a D-Link router the default IP address would be 192.168.0.1 The default username: admin The default password: leave the password box blank.
Sep 06, 2011 | Computers & Internet
Saying My Pin Code for my belkin g router is incorrect, but i am entering in the correct pin code off the label , so i dont understand why it is saying it is incorrect
There has probably been a change to the pin code. In order to use the default pin code on the label you will probably have to reset it to the default configuration. You can do this by unplugging the router. Find the reset button and using a ball point pen or other sharp object, hold the reset button down. While holding it down, plug the router back in and continue to hold the button down for at least 10 or 15 seconds. You may have to reprogram some of your settings but your pin code from the label should now work.
Be sure to email me back if you have any more questions orif you need any assistance with this solution. Thank you
Jun 20, 2011 | Computers & Internet
The internet guy was just here today in my new place but i wasn't here with him.To connect to the internet it is asking for a 8 digit pin code located on the bottom of the router. I can seee several...
When you say, "IT is asking for..." exactly what is "it?"
It sounds to me like you have a Linksys wireless interface (possibly USB) on your PC which assumes it is going to connect to a Linksys router, which would have that PIN code on it... but you don't own a Linksys router and therefore the whole PIN code protocol is futile.
Bypass the proprietary PIN code nonsense and enter the WEP or WPA password the installer gave you (if any; it's possible he didn't set any) to connect to your access point from your PC.
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g router won't broadcast my wireless internet!!!
find the back of router a small hole/pin then reset the booton then a 15seconds go go back normal the router.good luck
Jun 14, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
