Question about HP Officejet 7210 All-In-One InkJet Printer
Remove and ck right cartridge
I have a 7210 All in one that i can not get the "remove and ck right cartridge " error message off. I have taken out the cartridges and replaced them both....
  • 1 more comment
  • MikieC Jun 02, 2008
    I am having the same problem. I removed the color cartridge and immediately replaced it. I keep getting an error message that says "Remove & Check Color Cartridge. I have done it a zillion times and even put in a brand new cartridge and I get the same message.
    Maddening!!!
  • Anonymous Jun 10, 2008
    The x-bias spring might be dislodged or missing if the small plastic tab in the print carriage chute is broken.
  • kimmiejo Jun 17, 2008
    insert black cartridge message will not go away. I have new black cartridge but there is a metal bar that I think might be broken or not in properly. Does anyone know about this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
Posted on Jun 03, 2008
I am getting an error message remove and check right cartridge?
Replace the right cartridge with a new genuine HP cartridge.(not a re-fill)
If still does it check that the contacts are clean where the cartridge seats.(wipe with a q-tip)
Aug 31, 2010 | HP Officejet 7210 All-In-One InkJet...
Printer says to insert black print cartridge in right stall
Refer to printer manual as some of them require you to reset the software to accept new cartridge.
Manual here if you do not have one
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Sep 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
HP OFFICEJET 7210 ALL-IN-ONE
Time for a new pca carriage. part number C8963-60051. good luck finding one though. All your problems are caused by a stupid little plastic tab that used to hold the metal thing in place. now, it moves around when you put in a cartridge and doesn't make contact with the right circuits. I really hate HP for making such a crappy part and then having no way to replace it. Well, besides sending it to them so they can charge you $215+ to fix it. That's more than what I paid for new!!!
Aug 27, 2008 | HP Officejet 7210 All-In-One InkJet...
Re: Remove and ck right cartridge (by 4 users)
I would call HP regarding it and see if they accomodate you with an upgrade to another printer.
Jul 23, 2008 | HP Officejet 7210 All-In-One InkJet...
Remove and check right cartridge
Install a new cartridge or clean the contacts on both the back of the cartridge and the contacts where the cartridge is plugged into, with warm water. Dry both then reinstall. Make sure neither show any damage. I have seen inkjet printers where a small hole is poked into the traces where the cartridge installs into the printer, destroying it.
Mar 27, 2008 | HP Officejet 7210 All-In-One InkJet...
Right print cartridge issue
Some 3rd party cartridges are not perfectly manufactured and in many cases you'll need to press firmly (not hard) on the top front of the cartridge to ensure adequated contact is made wih the electronics on the cartridge and your printer.
Feb 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Black and color cartridges
have one black and one color cartridge in my printer but it keeps giving me an error message:
Oct 14, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
1,416 people viewed this question
Seeker5211
Seeker5211
