Question about SNK Blackmore Mobile Electronics Blackmore Mobile Blackmore In-dash Multimedia Player and Navigation GPS Units GPS Receiver
Had the Blackmore BIM-3005 player installed in my car, can't locate manual, can't seem to get the company to respond to my request for a replacement and cannot figure out how to get a CD to play.
  • Robert Struzinski Aug 07, 2013
    They won't respond ever, I can't even get them to tell me what pin out values are so I can make a wire harness.
    It seems that the people here that have manuals for these units just won't share them with others either!
Blackmore bim-4750 dvd not workig message when parkig brake supplied what do i do
Send me or post a clear picture showing the wire harness (connector with all the wires that plug into the back) fully top and bottom views and I'll tell you how to fix this really easily!
Mar 08, 2012 | SNK Blackmore Mobile Electronics Blackmore...
When i put acd or dvd in it will not turn it say dise error.
Try cleaning the laser lens. I assume you have tried commercially pressed discs not just DIY burns? (to eliminate possibility of disc compatibility). Did it ever work?
Feb 16, 2011 | Blackmore Mobile Electronics BMDTT6 Car...
My DVD 3005 is locked on a DVD do not know how it happened but obivously I have pushed the wrong button is there a common decode number I can use, I am unable to locate the manual for the player. Regards
I'm not sure whether this will work. Can you locate a small hole under the disc inserting outlet of your DVD player. If yes, push the eject button and insert a small pin well into the hole. The DVD struck in may come out in a few seconds.
Apr 07, 2010 | Philips DVP-3005 DVD Player
Router not responding to http request
possible firewall on the router check settings make sure its not blocking ping requests everything else works?
Jun 05, 2009 | Cisco (1841) Router (cisco1841)
I have lost the operation manual,how can I get a replacement.?
go to www.phillips dot com and there should be a link to download the manual
May 20, 2009 | Philips DVP-3005 DVD Player
Won't display photos from a CDRW
Check what type of file type the Kodak is creating, it may not be a JPG. If its not you would need to look in settings or check the manual to see how to change the camera so it saves the files as JPEG'S.
Or the long route compress them into JPEG'S on your PC.
Feb 16, 2008 | Philips DVP-3005 DVD Player
Need manual
the manufacturer is universal electronics, you can find their contact info on their website at www.tview.us . good luck
Jan 06, 2007 | T-View 15.3" Overhead Monitor w/Built-in...
SNK Blackmore Mobile Electronics Blackmore Mobile Blackmore In-dash Multimedia Player and Navigation GPS Units GPS Receiver Logo
133 people viewed this question
Top SNK GPS Experts
Will Halftowaite
Are you a SNK GPS Expert? Answer questions, earn points and help others
